Ok so I have a Samsung 2253bw that died on me the other day. I woke it up from sleeping and it flickered once and went black (as in the back-lights went out) I can see an image if I shine a light into the monitor. I opened it up and found 4 domed up caps on the power board. I replaced the bad caps (820uf 25v 105c) x 4 then tested. Still getting a solid power light and no back-lights (slight hum coming from inverter when plugged in).
Took it apart again and did some more research to find out about the small green pico fuse on the board which in my case was 4 amps. I couldn't find one around so I replaced it with a glass fuse (also 4amps 125v) soldered to some leads. It is set on the board away from everything and is not shorting on anything at all. I also decided to replace the 2 1000uf 16v caps on the board and the 1 330uf 10v (replaced with a 330uf 25v) I ordered the caps from Digikey. Now the monitor does something different. As soon as it is plugged in you can here an intermittent clicking from the power board and the power button does nothing. No power light at all.
It seems like this happened after replacing the fuse. My guess it that there is another problem here and when the fuse was replaced it is now evident. Im surprised replacing the blown caps didn't just fix it. Any ideas? I have videos but there just on my computer at the moment I can take a few pics of the board if its needed.
Is there anyone that knows the exact sequence of events pretty much that takes place upon inserting the power cable? there is one cap i did not replace near the power button connector but when the fuse was the pico fuse (blown) the power lights worked fine and I could push the button and see an image on the screen (with no backlights) . .. really sorry for the long post and it is my first so I apologize if I didn't include what i needed to I tried to be thorough I am just frustrated. I frequently repair small electronics so I am no stranger to a soldering iron all my contacts are solid (tested with a multimeter)
Any help at all id really appreciate it. This site is amazing thank you all for all you have contributed
