A friend brought me an IBM model number 6734_HBO (not ABO).
Background:
I plug in the monitor and it turns on for 2 to 4 seconds then turns off.
I opened it up and found a 1000uf/10V bulging. Replaced cap with a new one 1000uf/25V. Put monitor back together and powered it up. Still the same thing.......2 to 4 seconds on and then off.
What i have done:
1- replaced bulging cap. No change.
2-I checked ALL 4 lamps and they all seem to be ok. I used my home-made bulb checker.
3-Measured voltages at connector (see enclosed pic of connector):
Pin1=>13v when off. When on ~14V and then when shuts down voltage goes to 12.6V
Pin2=>13v when off. When on ~14V and then when shuts down voltage goes to 12.6V
Pin3=>0V
Pin4=>0V
Pin5=>0V
Pin6=>0V
Pin7=>4.96V
Pin8=>0.138V
Pin9=>when off ....0V.........when on....2.72V.
Note: See connector pic.......i dont seem to measure the 3.3V.
Note: When making measurements at the connector i did by accident short pins 4 and 5 just for a second. It does not appear to have done any damage since i still get the same error.......2 to 4 seconds to black.
4-I checked fuse located in the inverter section......seems to be ok.....0.2ohms.
5-I worked on a similar monitor as shown below. But not exactly the same.
https://www.badcaps.net/forum/showthread.php?t=10055
Any ideas on where to start.
Background:
What i have done:
Pin3=>0V
Pin4=>0V
Pin5=>0V
Pin6=>0V
Pin7=>4.96V
Pin8=>0.138V
