I initially created thread about this tv set with nothing on when plug in. It was diagnosed, with all the helps from this forum, to have a bad power supply. It has been collecting dusk until I found a PS to replace.
Now I have the set power on with red indicator as it plugs in and turns green as the ON button is pressed, but nothing on the screen at all. I checked the all PS output connectors and they all seem to have the correct voltages, except the Power_On is 4.5V instead of 5V like the board's legends suggested. I can hear the noise from the speakers but that's about it. All smd fuses on the inverter board tested good but I have not check to see if any voltage present at the inverter board, will do that later tonight.
Where do I go from here? any suggestion? thank you all very much. I will post some photos later as well.
