Ok, i swear, i'm running out of ideas
So, i've had this Alienware 17 R1 (Haswell) brought to me. Allegedly, the owner tried to undervolt the cpu(?) because he was having overheating issues. Odd / unlikely, but fair enough.
Initial status - laptop turns on (ie. the lights & hdd's & stuff), but that's about it. No POST, no backlight, no beeps, nothing at all, with or without RAM.
Step taken: fresh BIOS chip, programmed with a dump found online (de-whitelisted).
Result: Still no backlight, but "at least" now i get series of 7 (seven) beeps, which in Dell / Alienware language, means the CPU doesn't get detected.
Since the cpu had supposedly been messed with, i figured i'd try to eliminate that variable. Stock it had an i7-4940MX; i found an i3-4000M for not too much money, to use as a test-cpu. No dice, same 7-beep stuff.
I've yet to probe ALL the voltage rails, but the ones i could reach on the top of the board, all check out - 5v / 3.3v main rails, the 1.35v and 0.675v for the RAM, 1.05v, 1.5v. At least, at the point of generation, anyway.
I'm getting 1.7v on the VCC_CORE rail, which is a bit on the high side, and from that Th3_un1qu3 tells me, that happens when the cpu isn't detected (properly).
I'm attaching the schematics / service manual for this board.
So... What the hell's the "cpu detection protocol" in computers?
Now that i think about it, i'm almost starting to doubt the "validity" of that bios dump i found. But then again, complaining about the cpu is still more than it did when it first came in...
Any ideas, anyone?
Any ideas, anyone?
