P.O. says sound worked and no picture. For me Red light turns blue and it stays on. . No sound or picture. With flashlight I can see the menu come up very dim.
Nothing jumps out with back off except how little is in there.
Power supply
Tcon board and tuner board.. That's it. I get 167 volts on standby and 390 with set on across the large filter cap on hot side of supply. From other posts these are normal. On Connectors 1 through 5 I have a red and white wire each going into the panel on the left side. I assume these are feeding the led backlights. Do I test the output with a common ground or across each connector?
I have read that this set is prone to backlight failures but hoping it is the supply instead. No voltages are printed on supply so not sure what I should be seeing. And if these "backlight" voltages are safe to check. All these connectors come off the right side of the board which is the cold side. Also fuse on Tcon board is ok.
If someone could tell me what voltages should be there in those connecters going to the panel that would help. The board is MIP550D 5TC
Have pictures but for some reason Site says I do not have permission to post. Will work on that. and I can find no model number on it anywhere but I think the one in the post title is correct.
Power supply
