I have tried powering up with the Y or the Z SUS disconnected.
I have measured VS going into both Y and Z and it is the 203V on the sticker.
I have tried a new power supply board.
I tried disconnecting the main board ribbon cable from the control board and jumpered R51 and R52.
The panel appears unbroken. The unit was turned on when it went black.
The TV stays on and the remote control works.
I noticed a capacitor has fallen off the control board at location C12. Not sure if this happened after I took the back off and maybe my dog brushed by? But when I hold it in place, still no image. (Not sure when I hold it that it is making good contact, though.)
Is there another test I can try or another voltage to measure? As I remember, Va was good too, and there was negative voltage on the Y SUS out and positive on the ZSUS.
The only problem the TV had was a intermittent failure to sync up with HDMI inputs,which happened with multiple devices on multiple HDMI ports on the TV.
Thanks for any guidance you can supply, even if it is to give up!
