samsung not working
    samsung not working
    i have LE32D550 K1W Samsung doesn't work
    led blinks 4 error Tv not working , System board BN41-01603C problem but what's the problem in system board please i need help
    Electronic Engineer from Syria,Aleppo
    Re: samsung not working
    The blinks mean nothing on a Samsung TV. They are normal. Have you checked other faults, like to make sure the PSU voltages are OK and if the backlight will power on by unplugging the connector between main board & power board.
      yes backlight power on by unplugging the connector between main board & power board
      do you know what's the problem
        Something wrong on main board, check volt regs, and the CPU core voltages. Could be bad firmware.
          thank you tom ,i want service manual to this main board if you have to check volt regs
            check post 2 for service manual.
              I can not find it
