Re: a1278 emc 2351 bios needed ,
well it worked turned on 2 times but VERYYYY STRANGE .. it turned on only by cheking values on TPS51125 , specially after meausuring pin 16 and pin 17 , it simply turned on , after that disconnected and tryed to connect it by shunting g3hot pads , but nothing happen , so ok , i cheked pins and noticed also that if no keyboard ribbon attached i got 3.40 on the EN0 pin of tps51125 ,
once i insert the ribbon cable , there is no longer EN0 values , as also it will not turn on in any way ..
meanwhile , i removed the tps51125 and reinserted a new one (brand new) sudently i just touched the VREG5 pin and i noticed i add 5 volts .. cheked vreg 3 , also 3.3 volts . ok made the shunt on G3hot pins and machine turned on ... now let me chek if machine turn on also with the keyboard ribbon added.
Well with the ribbon keyboard cable , machine loose the Vreg voltages to 0.60 volts , and not turning on , also g3hot stay on 1.66 volts , if i remove the keyboard ribbon , machine have correct vregs and turn on once i shunt g3hot pins
i guess its a shorted keyboard
