So i got this monitor for free and I figured I fix it because when i got it and plugged it in the green power light would blink green now I replaced the 6 (470uf 25v) 1(220uf25v) 2(100uf25v) 2(10uf50v) and now it will come on for 4 seconds then shut off and the power light turns orange and I can keep trying it with the same results anything I can try next
kds 700p 2 sec crap
Re: kds 700p 2 sec crap
Is it plugged into running PC?Never stop learning
Some monitors won't power up with no signal, try it on a computer first. Also what caps did you use as replacements?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
2 seconds to black can be
a) bad caps
b) bad ccfls
c) bad ccfl wiring (especially the return wiring)
d) bad secondary windings on the inverter transformer
More details starting with post #19 at
Also, see budm's Inverter tester using old CFL
https://www.badcaps.net/forum/showthread.php?t=19987--- begin sig file ---
--- end sig file ---
Originally posted by tackleboxface View PostI hooked it up to a CPU with the same results I used radio shack caps
nichicon
If they are for switching power supply filtering circuits, then you need low ESR type due to high opreating frequency (50~100KHz) that it has to filter out, you can can long life time non low ESR 105c.Never stop learning
