The monitor will not turn on, have checked the power cable and the VGA cable both are fine.
The power on LED seems very dull and then goes out after a little while so i am assuiming there is a problem with the supply?
I have disassembled the monitor and on what appears to be the PSU PCB board, I have noticed that there are various caps that are buldging. So i intend to replace these. I have also checked the internal fuse which appears to be fine also.
2 x 10v 1000uf
2 x 25v 680uf
2 x 25v 220uf
2 x 25v 470uf
2 x 450v 100uf
2 x 25v 47uf
2 x 16v 470uf
2 x 16v 22uf
I have also notice a discolouration of the PCB board under two of the caps and two of the IC's.
I was going to install a chip holder and replace the two IC's which are 4511GED but i cant appear to source these from anywhere?
Does anyone know where i can source these IC's or a like for like replacement?
I will post pictures when i get home but i am unable to do this at present.
Cheers
Dan
2 x 10v 1000uf
2 x 25v 680uf
2 x 25v 220uf
2 x 25v 470uf
2 x 450v 100uf
2 x 25v 47uf
2 x 16v 470uf
2 x 16v 22uf
Cheers
Dan
