Hi all!
I've got a Samsung PS42C451B2D 42inch Plasma I'm having issues with.
Full disclosure: I've probably caused these issues myself, as I have very limited component level electronics experience. Now, onto the story
Was originally getting the red sparklies/snowing issue that seems to be common with older PDP units. Through reading info on this site, I (correctly) determined the problem was most likely out of spec Y-sus voltages.
Now, I tried to test the voltages using a multimeter. I began by testing on the PSU board between a point labeled VS-TP and the metal casing of the back of the screen. This resulted in a massive spark and a bang, and a scorch mark where I touched the negative terminal of the multimeter to the metal casing. Needless to say, I needed to change undies after that.
After that scare, I decided I would rather not try testing any further voltages and just play around with the potentiometers to see if I could make anything better.
I began by playing changing the VS-ADJ and VA-ADJ pots on the PSU board. This didn't seem to make any difference on the picture. I then had a crack at the Yfr and Yrr pots on the board on the lower left hand side (I believe this is the Y-sus board?) This improved the red snow issue, so I tweaked them until everything looked great.
I put the TV all back together, and enjoyed a few weeks of trouble free viewing. Then, occasionally, the TV would stop showing picture, however sound will still be fine. Turning the TV off and then back on again straight away would rectify the issue. This would happen every now and then, without any pattern. Sometimes it would be fine for hours with no issue, other times it would happen after 10 minutes
Then a couple of days ago, the TV just started refusing to turn on. The power LED is on, however when I try to switch the TV on, I can hear relays clicking, and then click off again straight away. The TV doesnt play its little power-on jingle or anything. I have not gotten the TV to turn on at all since this started happening. I've unplugged the unit from the wall for 24 hours etc, but no luck.
I've pulled the case off the back to see if there was any obvious issues, but could not see any blown caps or fuses or anything out of the ordinary.
Can anyone give advice on what I should be checking? I assume my earlier messing around with the pots on the PSU has something to do with the issues I'm seeing now. I'm hesitant to go poking around with a multimeter unless someone can tell me exactly what I should be touching with it to test properly.
Thanks in advance for any help!
