I got a box of supposedly bad hard drives, some of them appear to not be completely wasted incl. a 1TB 2.5" Samsung. There are pretty much screwed sectors there but I can not make that PoS to reallocate them. Now it does not seem there is whole lot of them (about 50), considering the data density; it is so huge for current drives that having 100% good surface is almost impossible these days. Manufacturers know that very well, what can be seen from huge number of sectors it has for reallocation until it is considered failed (old drive had that S.M.A.R.T. value about 100, here there is 252). So I was thinking if I make them reallocate and no more will appear under intensive stress, I can still use it somewhere non-critical, or resell.
However, it just does not reallocate. Usually the thing is able to write into that sector, only the read is than screwed. So all pending sectors are always miracously "healed" and dissappear. I tried Chek Disk, it always froze. HD Tune always wrote over it only to find it bad again during next read check. Hard Disk Sentinel, I think it is "repair drive" test (tried overwriting before, same as HD Tune) is stuck in a loop of reading bad-overwriting good-reading bad again loop for two hours now on the very first bad sector.
Is there anything else I can run to make the bloody damn thing reallocate it, or is it really only good to be run through grinder for aluminium?
