visio vx37l resistor indentity help
    tv model: vx37lhdtv20A
    power supply: DPS-247APB
    no standby power
    found two transistors shorted all ways (model STP12NM50FP )
    found one resistor burned up
    resistor Is burned right where the ohm is printed and I cant read it.
    I need help trying to figure out the value.
    It says "F1J' and also what looks like some symbol &"60B"
    The resistor goes from the positive side of main filter cap and connects to the drain of one of the blown transistors as well as one leg of a transformer
    PLease help If possible
    Re: visio vx37l resistor indentity help
    That is the fusible resistor, probably <1 Ohm range.
      thank you
      would you be able to recommend a replacement?
        Can you put a picture and some mark on the location of this F1J ?
          R805 I would say.
          I'll have a guess. First symbol is looking like a R so 0.? And the number has a curve so I'm thinking a 2 or 3. I'm going with 3 So 0.3 ohm.
          Let me know what the prize is if I'm correct.
            Originally posted by tw2005 View Post
            R805 I would say.
            Yes , It is labeled R3Ω ,so it's 0.3 Ω. You're a winner ..
              Do you have a live one in captivity to refer to? LOL.
                In my stock of used parts , i'm sure i can find a dozen , but still , Lebanon is very far , unless you wanna wait ..
                In case you didn't find it , i'm ready , send me your E-mail
                  I'm not the original poster.Not after one, I just wanted to know if you had one of these boards and confirmed it was that .
                  You seemed very certain.
                    Ah well ; No , i don't have the board , but i have the schematic , and frankly , this one came with many restrictions and warnings considering publishing . That's all..
                      sorry for being MIA. Busy Weekend.
                      Now that you say it. I think you all are right.
                      For the next $million question..........
                      How far do you think the damage went?
                      I have R623 reading 4.8ohms
                      R621A = 24.6ohms
                      R62B = 15.7ohms
                      R618 & R620 (resistors between source and gate) are 20kohms
                      reading 19.93ohm and 20ohms
                      What else should I check?
                      what are the chances the surge blew back into IC 601
                      thanks for the help amigos
                        SO I replaced the 2 transistors and the resistor.
                        Now I have standby
                        psON is up at 4.6V and visio turns from amber to white
                        BUT I'm only getting about 1-2V on my 12V and 24V
                        I checked and I'm getting 472Vdc on the big diode (ZD902) behind the transformer in the picture.
                        Any suggestions?
                        Also, theres a faint buzzing coming from the new transistors I installed. doesnt that mean the voltage is too low or something?
                          472v seems rather high
                            Sounds like using the wrong GND Ref. for the meter.
                              yeah I thought it sounded high. lol should I be using the negative side of the main cap?
                              should I measure ac or dc?
                                Negative leg of the main filter cap is the GND ref. for the primary side of the circuit.
                                  a diode will block ac, so when checking voltages on the cathode, you test in dc.
                                  WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                                    It will block half the cycle of the feeding AC in rectifying circuit.
                                    http://www.visionics.a.se/html/curri...ectifier1.html
                                      Thank you for the info guys. hot and cold sides confuse me
                                        ummm soo yeah using the negative leg of main filter cap got me 528Vdc on the cathode of that diode. and 406Vdc on the anode.
                                        I don't get it.
                                        With the device in standby i have 194Vdc on the cathode of the diode
