Something I've noticed from repairing a number of LCD monitors is they commonly use 25V caps on the secondary side (and seen a couple 35V even). However, in every case the secondaries were only 12V and 5V, or sometimes 13.5V and 5.5V rated (or some strange value there). Testing with a DMM shows that to be true
I stuck some 16V caps that I had in one to replace some 25V caps on the 12V line and naturally it worked fine... But I can't help but wonder why they used 25V. Is there a good reason behind it, or were they just trying to give a little bit of a buffer since they knew they were using junk caps in the first place?
I'm guessing the latter as that seems to make the most sense, but figured I'd double check with the pros here before I assumed too much and had trouble down the line with the 16V caps.
