I have a VX910 that died. The power light flashes, but the monitor will not turn on. When I opened it up, there were several caps with bulging ends. The large cap, which does not normally fail, was not only bulging, one lead fell off when I touched it.
After replacing all of the electrolytic caps with low ESR 105 degree parts, the problem persists. I've started doing some probing on the power supply board, and it seems that the PWM chip is not starting up. The 10uF startup cap has been replaced twice, just for good measure. There is 171 volts across the big cap. The only activity on the board is a spike about once per second, which is probably the kick starter pulse. It's hard to tell where it's coming from, but it would have to come from U320. In any case, I'm confident the problem is on the power supply board.
This is the first LCD monitor I've tackled. If I'd seen one working correctly, I'd have a better idea where to start. Thanks to SMITHWHO, I have the correct schematic. My best guess at this point is the PWM chip, U320. At no time is there a signal on pin 8, which is the gate drive for the MOSFET. Pin 2 is constantly low, and the optoisolator is not shorted. Is there anything else to check before replacing U320, which I'm probably not going to do.
The monitor is not worth fixing, but it's a learning experience for me.
VX910 Schematic
VX910 Schematic
