Sony BluRay Player - Locks up
    Model: BDP-S3100
    Will attempt to boot but gets stuck on logo screen. Sometimes it completes the cycle and I can power it on but it instantly freezes up again.
    I've tried holding down the stop button while booting as I read it resets the resolution and 3/5 times it'll load doing it that way but again will freeze while in the home screen. Not sure if it's just a coincidence that holding stop even helps or just repeated attempts to get it going.
    Would this be a firmware or hardware issue?
    It's a great wifi enabled smart BluRay player and I'd like to get it going again. It's just a little over a year old
    Re: Sony BluRay Player - Locks up
    Spoke to a Sony tech and they had me try resetting the player by holding play and power buttons for 10 seconds.
    That got it to turn off and attempt a boot but it still hangs. They wanted $80 for a replacement! Thing was $100 brand new.
    Anyone know if this issue sounds like firmware and it's pretty much "bricked"?
      I'd crack it open and look for bad caps.
      A working TV? How boring!
        I checked and the power board caps looked fine, don't have an esr meter. Main board had two smd aluminum electrolytic caps. Would those bulge if bad?
          Those caps would bulge from the bottom if they were bad.
          Have you checked any voltages?
            I would crack it open and reflow the power input section.
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            16 GB AData XPG Spectrix D41
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
              I checked voltages from psu to main board and didn't see any fluctuations. Only two voltages 5v and 12v.
                Power input section? Am I looking for a specific chip? I'll try to post pics when I'm home
                  First, I would try the power input connector.
                    Reflow that? It's only 4 terminals
                      Here are some pics. It appears there's always two 12v present with unit on or off and they're both present and don't waver.
                      I measured voltage at the + side of the two smd aluminum caps one is 5v and the other 12v, they might be for the bluray drive though considering their location.
                      Not sure where to proceed from here.
                        I would also reflow the 6 diodes.
                          On the psu?
                            So a friend has a similar unit without wifi but the power boards are identical, he let me swap them to see if there's any change and still giving the same symptom. That rules out any psu fault.
                            Any ideas what to try on the main board?
                              sounds like a firmware issue to me,have you tried looking for any updates via usb from sony?
                              fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                              please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
