Before I repaired the ymain and buffers on this set (hp-t5054) I broke two caps off the e-buffer when removing the mainboard assembly to get to the control board. I just replaced the two caps and the problem remains.
The line is where I would guess the addressing begins (on the left) but the broken caps were on the center right of the address board when looking at the screen. In other words not in the direct vicinity of the fault.
Is the affected E-Buffer to blame for this or can the Control Board cause this as that was replaced as well ?
(Hard to see the affected area because it blends with the black frame but the light is shining on it in the second pic)
