Are you sure it measures as OPEN and not as 0.00. we are only expecting it to be less than 1 ohm so meter should be on ohms20 or less.
What do the primaries on the old one measure
Can you unsolder it again and post pics of the bottom of both the old and new.
align them with the positioning pin at the same end.
I also notice there is some damage to the cap - does it just extend to the outer plastic?
yes the damage is only in the cover, i did it when i removed the old transformer that had an open winding, i dont have a good transformer out of the board, but i can desolder one of the other two original transformers.
comparing readings in the board without desoldering:
1st original 0.03ohm
2nd original(middle)0.04ohm
3st new open, infinite resistance
i believe the originals have 0.8ohm in each winding becuase:
middle pins are joined in the board. i suppose that the board is putting the 2 resistances(p1 to p3 and p2 to p4)in paralel, giving half the original resistance value for each winding)
anyway i think i will be desoldering it to check for sure
1-8 resistance: 1.040 K 4-5 resistance: 52.3 K(200K scale)
Interesting... I have a 2007wfpb that's doing the same thing. ...and the same transformer is bad. I wonder if there was some sort of error in the design or if this is purely a chance happening?
I have been doing some searching using google and I'm not finding any transformers that mach the 4001r714050 exactly, should this 4001K do the trick? Or is the 15K resistance enough different that it would cause problems?
If your meter reading doesn't change from not having the probes touching, then I would consider that "No Reading".
Right. My meter's default reading with the probes not touching is "1" on the left side, and nothing changes when I test those pins. I'm assuming that means the connection is open, yes?
Yep... that's open. Try testing on 2M range (or 20M or 200M if your meter has it), but it's definitely failed.
Well, now we have two people that need these units. I wish my Google-fu was better for this sort of thing, but I can't find any trace of the 4001R transformers anywhere. ...Of course Google probably ain't the best place to looks for specific electronics components, but I don't know where is.
