Blue blink of death on Samsung 2233RZ
    Hey guys,
    Recently bought a Samsung Syncmaster 2233RZ. I have a Geforce 7600GS/core 2 duo E6600 in a Shuttle SD30G2 Plus. I got the samsung to go with my Dell LCD so I could setup dual monitors. I unplug my Dell (uses VGA slot) on accident and plug in the samsung into the DVI slot. Turned it on and it was beautiful! Then I found out that I unplugged the Dell by accident, and RIGHT when I plug in the VGA slot, the samsung goes black! With the samsung plugged into the computer, it flashes the blue LED. When I unplug the DVI cable, it doesn't flash and the "check cable signal" shows and doesn't go away which I thought meant that it was either a problem with my GPU settings or computer settings. I've tried the source button and setting primary display as the samsung but it's just not being detected at all. Computer won't even recognize it as a device that i've plugged in. I'm hoping it's not a problem with the caps but I just wanted some insight if someone experienced this before. Thanks!
