Viewsonic LCD VA1703wb : opened one va1703wb model viewsonic monitor for the problem 'backlight turns off in 2 seconds'. Replaced all the capacitors still problem persists. It uses MP1008ES in the inverter board. When I downloaded the diagram it says the inverter contains OZ series chip on it!! Can anyone suggest where is the current sensing / ovpt for MP1008ES chip and how can I disable the ovpt??
Re: Viewsonic LCD VA1703wb
So does it use the MP10008ES PWM IC or the OZ XXXX BY O2 MICRO?
Do you have the diagram?
Does your board look like this?
http://s807.photobucket.com/albums/y...ic%20VA1703WB/Last edited by budm; 12-01-2012, 10:41 PM.Never stop learning
Ft pin4, when it is HIGH it will activate the shutdown. So monitor that pin with the meter.Never stop learning
So you connect the good set of lamps to this board and they stay on? I am a little confused.
"I have confirmed the lamps are ok by connecting different lamps."Never stop learning
Hmmm .....
Pardon me for butting in ...
Originally posted by roamingraman View Post... Is there a chance to eliminate the current sensing??
Originally posted by roamingraman View PostI have confirmed the lamps are ok by connecting different lamps.
Originally posted by roamingraman View PostThe board is not looking like this (*ttp://s807.photobucket.com/albums/y...ic%20VA1703WB/) as shown in that
Welcome to the forum-
We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
Examples of what is needed
https://www.badcaps.net/forum/attachm...1&d=1290283049
https://www.badcaps.net/forum/attachm...7&d=1280167246Please upload pictures using attachment function when ask for help on the repair
