I found SI 3120C is this the replacement component for SK 3120C? Also, if the regulator has an input v rating does that mean it has to take in that number of volts or that it cannot exceed that number of volts on intake?
Regulator SK3120C
Re: Regulator SK3120C
There is the limit how much the input voltage can be before the breakdown voltage happen. it is in the spec. There is also required minimum input to produced the required output voltage, the data sheet will have all those information.Never stop learning
