Hi
I have Uni-T UT203 clamp meter i use for troubleshooting things like heating elements and stuff at work. Now a microwave was dropped in my lap and i need to troubleshoot it.
My question is, would it be safe as in not damage the clamp meter if i used the clamp on the High Voltage side after the transformers in the microwave? Not sure what voltage is supposed to be there but quite a lot more then mains voltage. Don't have any meters that would handle that kind of voltage directly but thought it would be a quite good quick check if the clamp meter could tell me if its the upper or lower magnetron that's not outputting enough. Ofc i can measure on the input side but am just curious as what would happen, like will it just display out of range or something or just simply die?
