Thread Tools | Display Modes |
#1 |
City & State: United Kingdom
I have a Foxconn WinFast NF4K8MC motherboard which does not seem to power up if you short the PWR_SW leads. If you however short the PS-ON (green wire on ATX power connector) to ground it will power up and boot without problems. Once powered up, you can switch the board off by shorting the PWR_SW lead for a few seconds, after switching off though it will again not power up if you short PWR_SW, the only way to power up is to short the PS-ON to ground on the ATX power connector.
Yes I can probably make two switch, one to hot-wire PS-ON to ground to start and the other is the normal switch connected to PWR_SW but it's rather annoying. Any clues of what might be wrong? Thanks. |
#2 |
City & State: New Jersey, USA
Did you try another power supply?
ATX PSUs have a power good signal (gray wire) they output through the ATX connector if it's not there the mobo may not power up unless you force it directly. A power good signal won't be outputted until all of the rails are within voltage spec.
__________________
Elements of the past and the future combining to make something not quite as good as either. Last edited by Krankshaft; 06-02-2011 at 08:27 PM.. |
#3 |
Thanks for your response.
I had tried at least two different PSU, with them having either 24pin or 20pin power connectors but the effects are the same. |
#4 |
you can try replacing the ITE chip. it is responsible for power on
#5 |
City & State: opava
My Country: czech republic
I'm a: Knowledge Seeker
#6 | |
City & State: dayton ohio
i dont think its getting that far.no pg on +5stby.
something on the board may be telling the system the +5stby is out of range and this blocks startup till you force it on. Quote:
#7 | |
Quote:
#8 | |
Quote:
A MISTERY to me (it powers up directly, but not using the pson panel pins, but powers downs using the pson panel pins) Any comment? |
#9 |
you can read here some basic info about SIO and how it works
http://translate.google.com/translat...hoat-dong.html |
| Thread Tools | |
| Display Modes | |
