Hello, first, let me say thank you for all the knowledge that I have already gained from all of you. However, after all my searching, I still can't find a similar problem.
I was given a Vizio 32" that did not work. I don't own a TV (yet) and have little (no) experience with LCD's but have messed with electronics for years. I can't figure out what's happening with this one.
When I plug it in and turn it on, sometimes - usually the first time after I plug it in, the backlights will turn on and the logo will turn white. No picture, but I am not sure if there is supposed to be one. I can also turn it off, the backlights will go off and the logo will turn orange. If I try to turn it back on, the logo will turn white, but backlights will not come back on. Sometimes I can unplug it and plug it back in and turn it back on, and the backlights will come on again, sometimes they won't.
I have done the following tests:
Large capacitor ON/Off: 405/167. It appears to look good.
Fuse 1 on Power board off - 0, on - 120VAC
Fuse on Main Board F1 5.19 on and off
Fuse 2 on Main Board F2 0-off, 12.21 on
Regulators - Off (first three numbers)/ On (second three numbers). Also, I should note that I tested the regulators when the backlights were working... should I test them again when they are not working?:
TU52
EH13A
928k80
0
0
0
.01
.42
.1
U2
L311
G1117
0
0
.47
2.05
3.3
5.04
U8
L311
G1117
0
0
0
.01
1.25
3.28
U9
L311
G1117
0
0
.47
1.26
2.51
5.04
U7
1084
0931gL
0
0
.47
2.07
3.31
5.04
U4
L311
G1117
2.06
3.3
5.19
2.06
3.31
5.09
U5
L311
G1117
0
0
.46
1.38
2.63
5.04
U11
7805CT
RAG930G
0
0
0
12.18
0
5.02
Board numbers are:
Main: 0171-2271-2846
Power: 0500-0412-0737
At the power Supply, when it says 5V, I am getting 5.18 in all locations, at the 12V's I am getting 12.18. The on/off is showing 3.18.
I am lost in how to move forward. Any help in pointing me to a correct direction/path would be much appreciated!
Thanks!
TU52
EH13A
928k80
0
0
0
.01
.42
.1
U2
L311
G1117
0
0
.47
2.05
3.3
5.04
U8
L311
G1117
0
0
0
.01
1.25
3.28
U9
L311
G1117
0
0
.47
1.26
2.51
5.04
U7
1084
0931gL
0
0
.47
2.07
3.31
5.04
U4
L311
G1117
2.06
3.3
5.19
2.06
3.31
5.09
U5
L311
G1117
0
0
.46
1.38
2.63
5.04
U11
7805CT
RAG930G
0
0
0
12.18
0
5.02
Board numbers are:
Thanks!
