I was watching my Panasonic TC-P42G25 plasma two nights ago, and when i turned it off I heard a snap. Trying to turn it on since then results in the LED blinking once, and no picture.
I have electronics repair experience, but have little with flat panel TV's in particular. I left it unplugged for a day, to ensure the same LED one-blink. I found the service manual online, in which it maps one blink to a) Unknown SOS, b) Panel Information SOS, or c) PD4 Start SOS. This doesn't tell me much.
Googling around, I haven't found much on the single-blink code for my model. I pulled the power, "A" and "SS" boards to inspect them top & bottom. I checked for the following but everything looks good, I didn't see any:
- cracked or shorted transistors
- low value resistors that are open
- caps that have vented/bowed up
- bad fuses in power board
- any obvious/burnt signs of damage
I also looked at the SC board but didn't notice anything odd there.
More Googling, and I did find mention of checking for voltages on 4 test points: VSUS, VDA, VAD, VE. All four stay at 0 volts while I try to power on the set, and while the LED does its single blink. I find this interesting, since there has to be voltage somewhere powering the diagnosis circuit that blinks the LED.
I'm a bit stuck now. Any advice what I should test/inspect/kick next? I've seen several people mention 1 blink can point to the A board, although the service manual for my set doesnt mention this; rather it suggests A board issues are 2,3,5 & 9 blinks.
Are there any detailed guides on how to troubleshoot an A board for component failure? I'm worried just buying a replacement or repair for my A board either won't work or will just be killed again if something else is defective.
Appreciate any help. Thanks!
-Chris
-Chris
