I found an IBM monitor with a faulty analog to digital board. The screen is compatible with that Nec LCD1703M that has broken LCD screen.
I already connected the LCD signal connector to the Nec and it worked.
The only problem is that the backlight connectors are different. The IBM screen uses 4x 2 pin connectors (see photo 1) while the Nec screen has 2x 4 pin connectors (see photo 2).
I searched the web about conversion from one connector to another, but the most relevant info I found is this:
http://www.ccflwarehouse.com/cclawiwi.html ("step #2")
Has anyone done that before? Can you help me please?
