I have a HP L1940T LCD Monitor that doesn't power up & doesn't make any sounds. I looked at the circuit boards & I visibly see no signs of damage. I measured the voltage coming from the socket where the power cord is plugged in & it had the proper voltage. I do not no what to do next & would appreciate any help provided.
Hp l1940t no power
Re: Hp l1940t no power
OK, I need in focused pictures of the bottom side of the board and the Main board again.
Chek the fuse (white cylinder), and then check the voltage on that large cap, be real careful since you will be working on the hot (line) side of the circuits.
Post picture in the using advanced, attachment function.Never stop learning
What are the DC voltages on all the pins of connector CN951?--- begin sig file ---
--- end sig file ---
This a service manual that matches your chassis.Attached FilesNever stop learning
I went back and measured the small cap c927 located in the middle of the power board and I got a result of over voltage 0.L. Thanks to Budm providing the service manual I also measured the voltage for the pin8 of IC901 and got a result of 0.L over voltage. Does this mean my board is toast?
Please recheck the batteries in your meter and also try measuring something like a AA batteries or a 9-Volt batteries. It looks like the power supply not siwtching, need to do more components testing, but let's verify the meter first.Never stop learning
Originally posted by electrobe View PostI did as you had ask & checked a AA battery to make sure the meter was working properly and it was.
Most manual range multimeters show a "1" on the left hand side to signify out of range.--- begin sig file ---
Originally posted by electrobe View PostI went & remeasured C927 (results 0004 V) (which is a 68uF 25V capacitor) & IC901 pin8 (results 0162V). The capacitors on this board are from the manufacturer Elite. I removed the decimal in my auto range multimeter.
4 volts across C927 is too low a start voltage for IC901. You need a minimum of 10V. I would try changing C927 to see what happens.
Originally posted by electrobe View PostIt jumps back & forth from 9V to 10.40V.
Does the reading still fluctuate?--- begin sig file ---
Follow the steps on page 21 using budm's pdf file.--- begin sig file ---
