I would appreciate some leads - I'm having trouble narrowing in on the problem.
Symptoms, when connected to mains, will display red STBY light on the front of the TV, but when I attempt to turn it on via the remote or the TV press-button it briefly goes off and then back on again (less than 1 second) back to a steady red STBY light (ie. no sequence of error flashes). When this happens there is the sound of a relay activating - sounds like a single click but based on my testing it looks like it closes and then opens very shortly afterwards.
Samsung 64” Plasma TV, Model: PS64E550D1MXXY.
SMPS Power Board: BN44-00515A
Logic Board: LJ41-10272A
Main Board: BN41-01802A
X-MAIN: LJ41-09452A
Y-MAIN: LJ41-09453A
Y-Buffers: LJ41-010270A, LJ41-010271A
Overview image of board layout: PS64E550_overview_annotated.jpg
Connector CN801 Pin-outs: PS64E550_Connector_CN801.jpg
Connector CN802 Pin-outs: PS64E550_Connector_CN802.jpg
Voltages measured with multimeter/digital-oscilloscope at CN801/CN802 on the SMPS:
STBY Voltage: Sits at ~5.3V and then drops to ~3.7V every time the power button is pressed (refer to scope data PS64E550_Main_connected_15V.bmp)
PS_ON: Sits at ~3.3V until I press the power button, it then drops to just above 0V for about 250mS before rising to ~3.9V for ~250mS and then returns to ~3.3V again (refer to scope data PS64E550_Main_connected_PS_ON.bmp which shows where I pressed the power button 3 times about 1.5 seconds apart).
D5.3V: Sits at 0V and then briefly rises to ~4.4V every time the power button is pressed (refer to scope data capture at PS64E550_Main_connected_D5_3V.bmp).
VS_ON: 0V
VS_CON: 0V, with some noise spikes of up to about 0.8V (pos. and neg.)
15V: peaks to ~12.6V when button pressed and then drops down towards 0V slowly until the power button is pressed again (refer to scope data capture at PS64E550_Main_connected_15V.bmp).
The GREEN LED light on the Logic board does NOT flash, even briefly.
If I disconnect the cable between the SMPS and the Main Board and short the PS_ON to GND (Pin#1 to Pin#4), I can hear the relay clicking on and off with about a 1.5-second interval. While the relay is briefly on (<1 second) I can measure the following (measured at the CN801 cable):
STBY: short dip in voltage - to ~4.0V, then down to ~0.25V then up to ~1.6V for about 0.5secs and then a dip down to ~0.25V briefly before returning up to ~5.6V (refer to scope data PS64E550_Main_disconnected_STBY.bmp)
PS_ON: 0V (because it’s shorted to GND)
D5.3V: short peak in voltage - my scope shows it steps up to about 4.5V, a drop to ~4.0V for ~200mS and then ramps down more-or-less linearly to about 0V in the next 200mS, remaining low until the start of the next 1.5-second cycle (refer to scope data PS64E550_Main_disconnected_D5_3V.bmp)
15V: short peak in voltage: my scope shows it steps up to about 14V, a drop to about 12.5V for ~200mS and then ramps down more-or-less linearly to about 7.5V before the next 1.5-second cycle takes it up to about 14V again (refer to scope data PS64E550_Main_disconnected_15V.bmp).
VS_ON: 0.0V
VS_CON: 0.0V, but seems to have some spikes of 0.9V on this line (refer to scope data PS64E550_Main_disconnected_VS_CON.bmp).
If I disconnect the Logic board from the SMPS and jumper the VS_ON to the D5.3V pin (with the Main board disconnected and PS_ON shorted to GND at CN801 as before), I seem to get all of the VS (220V), VA(55V) voltages ok.
I cannot find any circuit diagrams or start-up sequence info for this TV, and I’m not sure what is causing the start-up sequence to fall over in my case. Anyone have any hints as to what I can look at. Is it just that I’m not getting the correct supply to the Logic Board?
Regards,
Tiny68
X-MAIN: LJ41-09452A
Y-MAIN: LJ41-09453A
VS_ON: 0V
VS_ON: 0.0V
Regards,
Tiny68
