MSI Z87-GD65 Gaming USB ports not working
    Hi Guys,
    I got MSI Z87-GD65 Gaming motherboard that is misbehaving.
    The board does not ready any storage devices, a usb keyboard and mouse work on all ports only in bios.
    I connected a hard disk with windows and the mouse and keybaord only work when connected to the usb 2 ports.
    I cannot update the bios because it needs to be done from a usb storage.
    I suspect there's a hardware failure but i am not sure what to test ?
    Thank you
    Re: MSI Z87-GD65 Gaming USB ports not working
    Originally posted by ScorpioMan86 View Post
    Hi Guys,
    Thank you
    Did you try these steps ? :
    1- Make sure if Legacy USB's option is enabled in Bios .
    2- Make sure to enable USB BOOT in Bios (in case you think that will solve your problem to flash Bios from USB ) ?
    3- Download the Motherboard USB 3.0 drivers from MSI website ?
    4- Are the devices you're trying to connect , compatible with USB 3.0 ?
    5- Are the devices you're trying to connect , compatible with your windows version , or they're too old for win 8 or 10 and/or 64 bits ?
