Cap identification
    Cap identification
    Hello everyone!
    I found a bunch of these caps in my Sharp LCD TV and would like to know if anyone knows the manufacturer or the brand name.
    It says something like "Dum? Con".
    I already googled the capacitor series, but only found capacitors of other manufacturers.
    Thanks.
    Re: Cap identification
    If this set was mine I would recap at least the power supply board and if you have a ESR meter I would check all caps that 100uf and lower to 1uf
    If you check low value UF caps and get a reading 1.0 or higher of ERS resistance I will check them with a new cap of same value and what the difference is this how good those caps are
    If you do not have an ESR meter then I would change all low value caps with new ones
    9 PC LCD Monitor
    6 LCD Flat Screen TV
    1 Dell Mother Board
    15 Computer Power Supply
    All of these had CAPs POOF
      Thanks for your reply.
      The TV set is working perfectly by now and it still has two years warranty, so I won’t modify or measure anything, which would involve desoldering, until it is really necessary.
      The caps I want to find out more about are in rather non-critical zones (audio amplifier and some signal processing circuit) — the OEM used at least Samxon GK and Capxon KF + GF capacitors together with one lonely Aishi RR capacitor in the power supply and LED driver section, so for a 240 Euro unit it could be worse.
