I have a Lochinvar LNV041 water heater from 2006 with a Honeywell
control for the power vent and the gas valve. The water heater should
last 10-12 years.
It was blinking error 84.
The electronics package is a white plastic assembly that is attached with one
screw and two tabs to the gas valve/tank temperature probe assembly. Three connectors to power and sensors easily disconnect.
The connection to the gas valve is three pins that stick out of the valve assembly.
The assembly snaps apart with a screwdriver slid into 5 or 6 locations. Start with the little tab, I think I went clockwise.
Two 330 uF SMD caps marked:
330
EHA
5HD
Needed to be replaced.
Jim
last 10-12 years.
330
EHA
5HD
Jim
