VAR00 LA-9201P short to ground
    Re: VAR00 LA-9201P short to ground
    took voltage reading at the location shown in the attachment and get 19v...
      B+_BIAS is pin1 of PQ3 and also pin1 of PC11.
      it is different from B+. I think you measured B+.
        These are the measurements I took from pq3 and pq4? These are the voltages prior to pressing the power... After pushing the power button the 5 volts drops to 0.00 and the 19.6 volts drops to 0.5....
          do you get any beep or blink code after turning on?
            not at all,,, after replacing the ribbon cable and the UL indicator board I get no beeps and the LED's dont light up... I know the board receives power, theres just no beeps or LED codes... Prior to that I did get the 7 beeps from the speakers...
              something is faulty on the board that makes the laptop to turn off.
              But it is not figured out yet.
                now open page45 of the schematics and measure the following points after turning on:
                PCH_PWR_EN , PCH_PWR_EN# , SUSP, SUSP# , SYSON , SYSON#
                  okay i get
                  0volts PCH_PWR_EN before power and 0volts after power is pressed
                  0volts PCH_PWR_EN# before power and .3volts after power is pressed and it drops immediatly to 0.00 this was at qz15 on page 45,, pin 3 gets 5valw...
                  SUSP = 0 volts
                  SUSP# = 0 volts
                  SYSON = 0
                  SYSON# = 0
                    now you would better reprogram the EC bios.
                    this may solve some problems of your laptop.
                    then we go forward to solve the remaining problems.
                      Sounds good ill pull both chips and reprogram them both
                        It would be better not to change the main bios if it is on a different IC.
                        make a backup of the main bios first.
                        If you reprogrammed EC and got no result, then you can attempt reprogramming the main bios.
                          no problem I always make a backup regardless... Thanks and ill be back in a few.
                            I tried looking to purchase the file and cant find it,, I'm assuming u2 and UH1 would need programming...
                              it is uh14.
                              probably you don't need to buy.
                              search Dell's website.
                              the main bios can be found in the following page:
                              https://www.badcaps.net/forum/showthread.php?t=53269
                              other technicians may provide the EC firmware here.
