Since shovenose got me started on it, i'm going to build one. Most of the specs i decided upon you can see here: https://www.badcaps.net/forum/showth...?t=7319&page=3
Considering the demand for cheap ATX PSUs here, i think i could even be in business. Time to give a friend of mine some competition hehehe. If anyone has something to contribute about the specs, comments are welcome. I'm thinking of something along these lines:
Other stuff you will need to borrow, steal or beg for to calibrate the tester:
So whatcha think? I'll start designing the ripple meters and come with some schematics.
- 700W loading capability. This should easily cover 90% of PSUs.
- Adjustable load by means of a variable voltage source driving a bunch of MOSFETs thru their linear range.
- Four amp meters and four MOSFET banks. Two for the 12v rails, one 5v and one 3.3v. Simple resistor loading for -12v, -5v and 5vsb, no amp meters needed there.
- Opamp-based voltmeters and ripple detectors. Latched LED indicators that show whether any of the rails has gotten our of spec during the test, and what got out of spec (voltage or ripple).
- No power supply required. The load tester shall derive all necessary voltages from the 12v rail of the PSU under test.
- Output terminals for connecting an external voltmeter or oscilloscope to any of the rails.
- Variable speed fans and over temperature protection.
- Cost: Under $150.
- Oscilloscope >10MHz
- High current, high precision amp meter
