Badcaps.net Forum
Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Computer Displays
Register FAQ Social Groups Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 04-18-2008, 02:33 AM   #1
vince88
City & State: SF Bay Area, California
Exclamation MAG Innovision LT716S Model 700P, seven bulged Xunda's
I just opened a MAG Innovision LT716S that does not power up. The power board is another typical case of 'bad caps' bulged and 'oozing on top', as shown in the pictures. These caps are all on the secondary side of the power supply: seven Xunda capacitors, including six 470micF/25V/105deg and one 220micF/25V/105deg. Failures of the components have taken out the two fuses on the primary [in-line with the mains VAC wires] and secondary sides.
vince88 is offline   Reply With Quote
Old 04-18-2008, 08:43 PM   #2
japlytic
japlytic's Avatar
City & State: Rockhampton, Queensland, Australia
My Country: Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
Default Re: MAG Inoovision LT716S Model 700P
First, check all pins on the bridge rectifier and MOSFETs on the primary side for any internal shorts with a multimeter.
If OK, replace all electrolytic capacitors with Nippon Chemi-Con KY Series, with the 400V/450V unit being replaced with a Nippon Chemi-Con KMG Series unit.
__________________
japlytic is offline   Reply With Quote
Old 06-18-2008, 12:52 AM   #3
vince88
Wink Re: MAG Inoovision LT716S Model 700P
I had time today to look again at the power board [1] the primary & secondary fuses tested OK when I used a sharp probe to get through the oxide [2] primary rectifier and both secondary Schottky dual-diodes [one dual common-cathode for the +5VDC and one dual for the +12VDC] tested OK with a multimeter on 'diode test' settings. I then recapped with capacitors bought at HSC in Sunnyvale: six 470mF/25VDC/105deg and one 330mF/25VDC, see enclosed photo. Note on the photo that the output pins of the power board are clearly marked +5VDC, +12VDC, GND, BRI, LPON.
The LCD now is fully functional.
Old 06-10-2009, 01:18 PM   #4
timothypeacy
I had the same problem with a MAG LT716s, I replaced the capacitors, The seven mentioned above and now the monitor works but, it only stays on for 30 seconds or so. I'm not sure what is wrong now but, I'll let you know when I figure it out.
timothypeacy is offline   Reply With Quote
Old 06-11-2009, 01:35 AM   #5
EGuevarae
EGuevarae's Avatar
City & State: Chiriaco Summit, CA - near the AZ-CA Border
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
Question Re: MAG Inoovision LT716S Model 700P
Quote:
Welcome to the forums
Please give some more info on what you did:
  • What caps did you remove (brand/series)?
  • What caps did you install (again, brand/series)?
  • It shuts down only the backlight or all the unit shuts down?
__________________
  • ASRock P43DE
  • Dual Core E6300 2.8GHz
  • 8gb DDR2-1066
  • 4 1TB SATA2 WD HDDs (2 mirrored volumes)
  • 22x SATA DVD+RW
  • Windows 7 Pro x64
  • GeForce 8500GT PCIe
    2 x Vewsonic VP2130 21"
EGuevarae is offline   Reply With Quote
Old 07-05-2009, 06:52 PM   #6
Badcappy
Banned
Interesting, had a similar problem with a PrOview 700P (same thing?) with a very similar power supply unit. It powered up initially for ~10 seconds, and thereafter would only flash the power light (it was struggling to stay "on.")
The seven Xunda's were popped, fuses and everything else looked good, so recapped and reassembled, works great.
Badcappy is offline   Reply With Quote
Old 07-05-2009, 07:05 PM   #7
EGuevarae
EGuevarae's Avatar
My Country: USA
Proview 700P, KDS 700P, MAG 700P, all the same ugly beast as long as they are "whatever" 700P
Old 01-27-2011, 02:28 AM   #8
demetrio
First of all...
Hello.
Me too!
My MAG LT716s was in my closet for almost ummmh... im not sure... a long time... in this new year cleanup i found it and i felt nostalgic then
i recapped the damn power supply and it worked!...
For a few minutes at least, now i turn it on and the light in the lcd goes away inmedeately... well in 1 second.
i can see the image but no backlight at all... i was wondering... should i threw it away? kick the capacitors out of the #$%&# thing ? or sacrifice a virgin in the name of the gods of the valhalla to make it work?
PD: thanks for the help in advance and sorry for my bad english.
demetrio is offline   Reply With Quote
Old 01-27-2011, 04:00 AM   #9
Rtech
City & State: Harrogate UK
Its not just those caps that fail,but also C10 and C11, next to each of the Inverter transformers.Measuring ESR in circuit,shows they look ok,BUT as they are across the transformers,this confuses the issue,and they usually fail on ESR testing when out of circuit.
Rtech is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2017
Powered by vBulletin ®
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
