Badcaps.net Forum
Go Back   Badcaps Forums > Battling the Bad Capacitors > Identifying Bad Capacitors and Related Symptoms
Thread Tools Display Modes
Old 09-28-2007, 01:46 PM   #1
Krankshaft
Knife Wrench!
Krankshaft's Avatar
Default Capxon Capacitors?
What do you guys think of Capxon capacitors or as I call them Crapxon capacitors .
No doubt they're trying to play off the Samxon name.
I have read in the bad caps sticky that they are on the bad caps list but I have read in other places. Where people think they're ok and use them on power supply recaps.
I personally stay away from them I'm more of a Nippon Chemicon/Panasonic kinda guy.
What are your thoughts?
__________________
Humanity has proven itself to be quite adept at making mistakes.
Hell it's the only thing that we truly excel at !
Guns don't kill people. People kill people guns defend people from people with smaller guns.
Krankshaft is online now   Reply With Quote
Old 09-28-2007, 02:24 PM   #2
willawake
Super Modulator
willawake's Avatar
Default Re: Capxon Capacitors?
i think they are ok in psu never seen them in anything else. i think they were before samxon though?
nobody took issue with rubyCON nichiCON chemiCON so what the hell....
willawake is offline   Reply With Quote
Old 09-28-2007, 03:44 PM   #3
toastygoodness
haha i've always wondered the what the con meant.
toastygoodness is offline   Reply With Quote
Old 10-03-2007, 12:19 PM   #4
yanz
yanz's Avatar
Send a message via Yahoo to yanz
for me, i have found same failed capxon caps on several psus so i dont consider them as good caps.
the blue capxon can fail with visible damage. the black one can fail without showing any sign of damage.
__________________
days are so short when you actually do something..
Proccessor...[AMD Athon64 X2 - Brisbane 5000 BE 2.6GHZ @3GHz]
Motherboard...[Biostar TF7050 M2]
RAM...[2x1GB Corsair TWINX PC6400 5-5-5-18-22]
Optical...[LiteOn DVDRW SATA]
HDD...[Seagate 160GB SATA]
PSU...[Seasonic SS-300FS 300W]
Case...[Simbadda Sim-V Case]
Monitor...[Samsung SyncMaster CPN17L]
FAQ | Forum navigation | Folding for Team 49813
yanz is offline   Reply With Quote
Old 02-05-2008, 05:49 PM   #5
PCBONEZ
PCBONEZ's Avatar
>> rubyCON nichiCON chemiCON <<
>> i've always wondered the what the con meant <<
CONdenser - The old name for caps. [Still used in some places I think.]
__________________
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 02-05-2008, 06:49 PM   #6
Krankshaft
Knife Wrench!
Krankshaft's Avatar
Oh duh .
I know the name condenser since I used to repair and read old tube radio service manuals where they referred to them as condensers.
An even funnier thing I read in an old manual was something to the extent of.
When you are soldering wires together and you need a third hand.
They said to hold the wires together with one hand with the soldering iron in the other and to put the solder in your mouth and bring the solder into contact with the wires.
Solder + Mouth = Bad
Old 02-05-2008, 08:16 PM   #7
PCBONEZ
PCBONEZ's Avatar
I've been known to put the iron in my mouth...
.. but not just after holding it with my toes.
Old 11-30-2009, 08:33 AM   #8
anchorbeach
CrapXon is a good name for these elctrolyitical turds.
I replaced them on mother boards, power supplies and audio boards. They are garbage.
My $2000 42 inch Samsung commercial grade monitor is filled with them. I just replaced a half dozen of them and they took out the motherboard for the MajicNet feature along with them. Lucky I have a spare board
anchorbeach is offline   Reply With Quote
Old 11-30-2009, 02:30 PM   #9
Chuck F.
On the weekend I picked up an Viewsonic 17" LCD monitor cheap which I've fixed already. Replaced a couple of Capxon's that had a bit of crusty brown residue on top. Monitor was a little short of four years old. Not a bad little unit, the base needs some weights.
Chuck
Chuck F. is offline   Reply With Quote
Old 11-30-2009, 05:58 PM   #10
i4004
i4004's Avatar
yes, there is doubt, because (same as willa said) i think they're acutally older than samxon...
there are much better companies, and much worse(with more screwed up series ie overall bigger number of junk caps in the field)...
stay away if you can do better.
__________________
...Another city goes by, in the night...
i4004 is offline   Reply With Quote
Old 02-15-2010, 01:23 PM   #11
gblades
I reconditioned the powersupply in my Thompson Sky HD satellite received at the weekend. These boxes are well known to have poor power supplies.
All the capacitors were capxon and I replaced all 15 of them. Two were so bad the ESR meter thought they were still in circuit. One other had a poor ESR and one had a poor ESR and a cap readong of almost half what it should have.
gblades is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2010
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Advertise on this forum!
