Badcaps.net Forum
Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Laptops, Portable, and Mobile Devices
Register FAQ Social Groups Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 03-03-2013, 12:23 PM   #21
rtstorm
rtstorm's Avatar
City & State: Croatia, Osijek
My Country: Croatia
Line Voltage: 230V 50Hz
I'm a: Knowledge Seeker
Default Re: Toshiba Satellite L655 (HannStar J MV-4 94V-0)
i am sorry, my mistake the voltages on Q6002 are 19V on one side and 0.54 on other side. Sorry
__________________
...the quieter you become the more you are able to hear...
rtstorm is offline   Reply With Quote
Old 03-03-2013, 12:39 PM   #22
Tuomo
City & State: Sievi
My Country: Finland
I'm a: Professional Tech
Quote:
No problem.
Measure U6000 PIN: 3, 4, 10, 19, 22, 24.
Measure R6005 resistance.
Battery ON/OFF.
Tuomo is offline   Reply With Quote
Old 03-03-2013, 12:58 PM   #23
rtstorm
rtstorm's Avatar
My Country: Croatia
Pin 3: 16.8V
Pin 4: 17.8V
Pin10: 18.6V
Pin19: 18.3V
Pin22: 17.9V
Pin24: 18.9V
Value are the same with battery and without battery.
Old 03-03-2013, 01:07 PM   #24
Tuomo
City & State: Sievi
My Country: Finland
Pin 3: 16.8V
Pin 4: 17.8V
Pin10: 18.6V
Pin19: 18.3V
Pin22: 17.9V
Pin24: 18.9V
Ok. I have to check those values.
PIN24 looks high I think it should be 0V/3V. This Enable/Disable chargin.
Measure those same PIN AC OFF.
Pin 10 should be 0V when AC ON.
If PIN10 not change when AC ON/OFF U6000 not notice AC Adapter.
Old 03-03-2013, 01:25 PM   #25
rtstorm
rtstorm's Avatar
My Country: Croatia
i try measure only with battery, and i got 0V on all PIN. I check battery and it is 0V, so battery is dead.
And i check again PIN10 is 18.6V with AC.
Old 03-03-2013, 01:27 PM   #26
spleenharvester
spleenharvester's Avatar
City & State: Telford
My Country: UK
I'm a: Hobbyist Tech
Been reading up on these since I may get a dead board to play around with myself - it seems replacing U6000 very often fixes the problem.
spleenharvester is offline   Reply With Quote
Old 03-03-2013, 01:28 PM   #27
rtstorm
rtstorm's Avatar
My Country: Croatia
I replace it, but still no power
Old 03-03-2013, 02:51 PM   #28
Techie666
City & State: Morelia, Mich
My Country: Mexico
I would check D6000, C6023, R6013, R6012, C6028, R6005, R6016, check for correct values, open or shorted components. also make sure L6000 is not grounded.
If all checks ok and you find no grounded areas that shouldn't be, remove U6000 and test the relevant input/output pins without the IC to rule out a damaged U6000. post your results.
Techie666 is offline   Reply With Quote
Old 03-03-2013, 03:15 PM   #29
rtstorm
rtstorm's Avatar
My Country: Croatia
ahh, i made mistake. I give you wrong readings (my stupid multimeter) sorry.
correct one are:
Pin3: 2.32V
Pin4: 1.35V
Pin10: 1.15V
Pin19: 1.06V
Pin22: 1.37V
Pin24: 0.4V
this is only with AC on, no baterry. But i try plug in the battery nothing have change in values.
Old 03-03-2013, 03:46 PM   #30
rtstorm
rtstorm's Avatar
My Country: Croatia
I found that R6016 is 2.2kOhm and i think it should be 10 Ohm, it has markings 100 or 180 or 130 (cannot be sure).
Old 03-03-2013, 04:07 PM   #31
Francisco.s
City & State: Alicante
My Country: Spain
L6001 PIN 1 and PIN 2 =19V, D6005 PIN1 and PIN2 = 19V
D6005 sohuld also have 19V at pin 3, if not, it is open and should be replaced.
Francisco.s is offline   Reply With Quote
Old 03-03-2013, 04:31 PM   #32
rtstorm
rtstorm's Avatar
My Country: Croatia
yes it have 19V on pin 3
Old 03-03-2013, 09:15 PM   #33
Techie666
My Country: Mexico
Are we looking at the correct schematic? if so where is the rest? it sounds like you need QUANTA BL7. you can get proper values from schematic.
New readings change things. measure resistance to ground on U6000 pins 3,4,10,19,24,22 post results.
Old 03-04-2013, 07:28 AM   #34
Tuomo
City & State: Sievi
My Country: Finland
correct one are:
Pin3: 2.32V
Pin4: 1.35V
Pin10: 1.15V
Pin19: 1.06V
Pin22: 1.37V
Pin24: 0.4V
If those are corretly measured values.
PIN3 should be 19V.
If PIN3 = 2.32V U6000 not works.
Follow Techie666 advice, and after that measure R6016 PIN1,2.
Old 03-04-2013, 12:40 PM   #35
rtstorm
rtstorm's Avatar
My Country: Croatia
i put back the old U6000 (maybe i mess the new one when i was soldering on board)
So i put the old one and i got 4.6V on PIN3
I check the R6016 and i get on one side 19V and other side 4.6V. So i am guessing that this resistor is preventing 19V to come on U6000 PIN 3.
I also measure the resistor of U6000 (the one that is right now on board)
PIN3: 41.3k Ohm
PIN4: 445k Ohm
PIN10: 8M Ohm
PIN19: 4k Ohm
PIN22: 430k Ohm
PIN24: 21k Ohm
Old 03-04-2013, 03:47 PM   #36
fddizon
City & State: Forbidden
My Country: Philippines
Line Voltage: 220v 60Hz
do you get cpu voltages?
fddizon is offline   Reply With Quote
Old 03-04-2013, 03:50 PM   #37
rtstorm
rtstorm's Avatar
My Country: Croatia
Hmm, where can i check that?
Old 03-05-2013, 07:47 AM   #38
Tuomo
City & State: Sievi
My Country: Finland
PIN3: 41.3k Ohm
PIN4: 445k Ohm
PIN10: 8M Ohm
PIN19: 4k Ohm
PIN22: 430k Ohm
PIN24: 21k Ohm
Remove R6016 and measure resistance should be 10 ohm.
U6000 chip has not short circuit.
There is no CPU or other voltages before U6000 works or using Battery.
Old 03-05-2013, 01:23 PM   #39
rtstorm
rtstorm's Avatar
My Country: Croatia
i remove R6016 and resistance is infinite (cant measure it)
Old 03-05-2013, 01:31 PM   #40
rtstorm
rtstorm's Avatar
My Country: Croatia
i have 18.9V on U6000 PIN3
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2017
Powered by vBulletin ®
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
