Badcaps.net Forum
Go Back   Badcaps Forums > General Topics > General Computer Discussion
Register FAQ Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 04-16-2007, 01:21 PM   #1
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
Default Cooler Master Centurion 5
This is one sick case. I think i will get another one. Pity about the 80mm front fan though. Pics came out a bit crap.
Front panel is part aluminium. The aluminium side edges look very good. The grilles also. The panel is solid and comes off the case nicely without breaking things.
The bay covers are grilles and they have dust filters at the rear.
When the front panel is removed the areas for the front panel connectors and the power, reset switch and led remain attached to the case. This is very good so there is no fiddling with wires. The hdd led is a very nice blue. I did not see what the power led was yet cos it was connected wrong.
room for some cable tidying at the side.
the bays have a locking device on one side. its not too bad.
single 120mm fan for the rear and 80mm for the front. both were very quiet cooler master models
curiously you can put screws on the other side. the technician who assembled the case did so i see his faith in the locking devices......
price : 49 euro (without psu)
__________________
willawake is offline   Reply With Quote
Old 04-16-2007, 02:24 PM   #2
Per Hansson
Per Hansson's Avatar
City & State: ----
My Country: Sweden
Line Voltage: 230v 50Hz
Send a message via ICQ to Per Hansson Send a message via MSN to Per Hansson
Default Re: Cooler Master Centurion 5
Quote:
Why not just take your laser cutting machine and mod it for 120mm?
http://www.badcaps.net/forum/showpos...&postcount=134
Per Hansson is offline   Reply With Quote
Old 04-16-2007, 02:27 PM   #3
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
smartass
Old 04-16-2007, 02:35 PM   #4
Galvanized
Galvanized's Avatar
City & State: SoCal,USA
Mod it for a 92x38...If it will fit.
Silverstone offers 90mm fans that mount on 80mm fan holes.
Yes, it is a nice case.
Galvanized is offline   Reply With Quote
Old 04-16-2007, 02:43 PM   #5
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
i aint modding nothing. its not mine. The next one will be mine.....
Old 04-16-2007, 02:49 PM   #6
dood
Deputy dood
dood's Avatar
City & State: Berwick, PA
My Country: USA
Line Voltage: 120VAC 60HZ
I'm a: Hardcore Geek
I have personal experience with the Centurion 5 as well, and it's a great case to build with!
dood is offline   Reply With Quote
Old 04-17-2007, 12:41 PM   #7
WNG
WNG's Avatar
City & State: Valley of the Sun, USA
Send a message via AIM to WNG
Nice review and pics!
Cooler Master is really catching my attention lately. The cases are very smart looking, and the design and construction looks well done. The only questionable area is the power button assembly in front of the 80mm front fan. Not only being 80mm is a negative (could be bigger for better flow/noise), but the button assembly blocks the intake, and that also cause turbulence noise.
So, how is the steel construction? As thick as, say, In-Win, Antec cases?
WNG is offline   Reply With Quote
Old 04-17-2007, 01:47 PM   #8
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
not sure about the steel thickness cos i received the pc built . I doubt it is on a par with the chenbro built antec ones, seems pretty standard low end stuff. its ok though, no complaints. A Lian Li which would probably solve your cooling complaint would be instead of 49 euro, 89 euro.
Old 04-19-2007, 11:27 PM   #9
randomchance
I got the Centurion 532 a few weeks ago to replace my old no-name case that housed my last 3 computers. Its the one with the vertical aluminum bars on the front, the buttons on the top, and a 120mm fan tucked away in front of the hard drive bays. I put another 120mm fan in the rear an mounted my hard drives with an empty bay between them. My system temperatures have dropped about 3-4 degrees C in the new case and my HDD temps have dropped by about 8 degrees. And the whole front is that cool looking black mesh with filters behind then whole thing to stop the dust bunnies from nesting in the case. Everything I have in there fit perfect and went together pretty painlessly, even the no-tool drive bays and rear slots work well. I really like the Centurion line, CoolerMaster hit the nail on the head with these cases!
randomchance is offline   Reply With Quote
Old 04-20-2007, 01:10 AM   #10
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
especially the price
Old 04-21-2007, 06:56 PM   #11
WNG
WNG's Avatar
Heads up!
Those interested in the case, it's selling for $29.99 AR at CompUSA.com
http://www.compusa.com/products/prod...ct_code=319347
Old 04-22-2007, 12:24 AM   #12
willawake
Super Modulator
willawake's Avatar
City & State: Αθήνα
its 69.99 now
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2013
Powered by vBulletin ®
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
