Generic router not assigning IP?
  • stevo1210
    • Oct 2006
    • 4156
    Hello All,
    I have a Skymaster 8 Port Network switch that used to assign IP adresses and now wont?!
    It used to assign IPs but now the Windows XP taskbar always says Limited or no network connectivity? but its fine under windows 98,ME,2000 but no packets are received, only sent, looks to be that it doesnt respond anymore?
    I don't know whats wrong with it.... i opened it up and the caps are all fine .... the circuit looks very simple though, a few resistors, a chipset and a few caps. If give it a manual fixed IP, it works flawlessly, i could see the surrounding PCs but auto IP used work but what happened now?!
    The lights at the front all work fine. it powers up fine too. I can only guess now that the computer fixer wannabe (not me) who dropped it on the tiled floor a few times while untangling cords probably screwed it up. The drop was pretty hard.... the cover actually came off?! im having an idea that i lost $45 during that fall.
    Im very sure it was fine a while back, it used to work fine, at the time i wasnt even a computer nerd and i could still use the net with it by just plugging in some random cables and setting up a network with windows network setup.
    Anyone got any ideas to what may have happened? the IP function just died one day.... as far as i can remember i think it had I.Q caps in it.... not sure.
    I'll update it tomorrow when i have time to open it back up.
    Thanks.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • pentium
    • Mar 2006
    • 2778
    Re: Generic router not assigning IP?
    Network switch
    Are you sure you know what a router looks like?
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
    • stevo1210
      • Oct 2006
      • 4156
      Ok, now you have a point, Pentium.
      I'm quite confused about the term router and network switch.... I know i learnt it at school.
      As far as i know, if i wanted to share my ADSL connection i would buy a router and if i wanted to run a private network, i'd need a network hub or a network switch.
      Well the box does say 8 port network switch....
      • gonzo0815
        • Feb 2006
        • 1600
        Jepp, usually a switch can`t asing IP numbers. Any way, i have some Skystar switches too, and all have had bad G-Luxon caps at the primary stage in the SMPS. I replace those and the seconadry caps to and i never have had problems again.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          how about a simplified example. if you have a switch you have a LAN (Local Area Network). Your lan will have a subnet.
          so for instance you set the subnet mask
          255.255.255.0
          now you can set the ips for the computers connected to the switch as follows
          192.168.0.1
          192.168.0.2
          192.168.0.3
          etc.
          youd give the computers the IPs statically or you could have a DHCP server assigning the IPs from a range.
          the switch allows the computers within the same subnet of the lan to connect to each other.
          but now you want to send traffic outside your LAN. you want to connect to a server on another network. you cant do that with a switch. you will need a router on both networks and then the routers can figure out how to pass traffic between the two networks. the routers provide the WAN (wide area network) link.
          so yeah accessing the internet means you are going outside your subnet so you need a router if you wanted to connect your network to the internet. I doubt if your switch is assigning IPs....
          what model of device are you using to connect to the internet?
          • stevo1210
            • Oct 2006
            • 4156
            well, right now im planning to run a private network for gaming but this switch wont work properly.
            But on the other hand i do have a DLINK DSL-G604T wireless router with 4 LAN ports and ADSL modem, like an all in one thing. I use it to access the net and also send my wireless transmission. It could be used for gaming too....
            That works well.
            • gonzo0815
              • Feb 2006
              • 1600
              Well, the D-Link is a gateway, it includes an DHCP server. Thus it can asing IP numbers. If you only have an switch in your network, you have to set the individual IP numbers at every system as a static one like Will has explained. A switch does nothing than passing the the messages from the concected devices to their destination port. I don`t think that there is any failure of this switch, as long you don`t have setuped the network manualy.
              • stevo1210
                • Oct 2006
                • 4156
                I have some images of the internal components, anyone have ideas to any of these components? The caps are KHC? havent heard of them before. I'll send more pictures afterwards.... my cameras battery just died, sorry, i could only get two images up.
                Thanks.
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  no shit. theres not much there.
                  anyway its not going to assign ips
                  so its working as it should
                  the only way ips will be assigned is if you connect it to the d-link.
                  • stevo1210
                    • Oct 2006
                    • 4156
                    Thank you very much, Willawake and everybody else. I have success now, after connecting it to the D-Link Router it works fine and IPs are also assigned automatically.
                    I guess that the switch is all fine now, turns out nothing was really wrong with it.... maybe apart from missing screws, but that can be fixed easily.
                    Thank You
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      He he he i am not shure if you have learned the lesson , any way if this switch will someday refuse to boot up, or realy won`t work, than you can replace those KSC crap caps. I have found some of them in many PSu`s 5v SB supply circuit, and they are failing alway very early and realy worse with severe bulging & leaking. But this is probably not only due the inferior quality of those caps, but more likely as those PSU manufakurers have used caps with inadequat ripple capability. That said, i think they should last some time under that not that harsh conditions in your switch.
                      • stevo1210
                        • Oct 2006
                        • 4156
                        Thanks gonzo0815, i am actually considering to recap this switch just to be on the safe side.... They are currently KHC 470uf 25V -40+105.
                        If i get around to recapping it, do the capacitors have to be low-ESR.... i am only guessing that the current caps are general purpose because they are in a network switch?
                        If they are just General purpose capacitors then i can replace them with the Hitano brand capacitors at my local electronics store.
                        Thanks.
                        • gonzo0815
                          • Feb 2006
                          • 1600
                          The left side of the circuit is an MC3XXX SMPS, thus i would use high quality long endurance low esr caps like Panasonic FC FM or equivalent series from others. I would certainely not use ultra low esr caps for thsi circuit. The VRM on the right side is an linear converter, thus you can use GPO caps or the same as on the left side. But i would avoid again ultra low esr caps on this circuit too. The other caps, i would use something very long lasting like Rubycon ZLH or similar. But GPO caps would be fine to. Anyway, i would use for anything 105°c rated caps.
                          • howardc64
                            Samsung UN55JU650DF network/streaming problem
                            by howardc64
                            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                            07-09-2025, 12:44 PM
                          • japlytic
                            Maximum speed should be marked on network ports
                            by japlytic
                            I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                            One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                            12-19-2024, 05:04 PM
                          • mecha1166
                            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                            by mecha1166
                            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                            11-25-2024, 05:22 PM
                          • CapLeaker
                            Dell ATX PSU won’t start, but forcing it works fine?
                            by CapLeaker
                            Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                            Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                            10-28-2024, 06:59 PM
                          • hikomalek
                            SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
                            by hikomalek
                            Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
                            When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
                            Transformer:
                            |Info| Primary | Aux | AB | CD|
                            |Ratio|1|25|40|12|
                            |Voltage AC|230V|9.2V|5.8V|19V|
                            |Voltage DC (*1.41)|230V|13V|8.1V|27V|
                            I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
                            09-19-2025, 03:30 AM
