Badcaps.net Forum
Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > General Electronics
Register FAQ Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 07-25-2012, 04:22 PM   #21
JonathanAnon
City & State: Kildare
My Country: Ireland
I'm a: Knowledge Seeker
Default Re: Can capacitor dielectric be black??
Quote:
Originally Posted by ben7 View Post
If you don't have a spare 3.25A fuse, just use a 3A to 2A fuse to test it. One thing is for certain, NEVER put in a bigger size fuse!
There's a 3.15A 250V fuse on this XBOX board as well.. I assume it would be fast blow (same as the monitor).. surely no reason for it to be time delayed?
JonathanAnon is offline   Reply With Quote
Old 07-25-2012, 05:31 PM   #22
JonathanAnon
My Country: Ireland
http://omg.wthax.org/26072012901.jpg
Just soldered in the 400v cap and 3.25A fuse from the XBOX in to the LCD Screen.. What do you think Ben, do you foresee any problems getting the cover back on.. .. the original cap was 25mm, this one is 40mm.. I'll power it on and see what happens.
Old 07-25-2012, 08:11 PM   #23
JonathanAnon
My Country: Ireland
Okay, just to update.. thanks again to all who have helped..
I plugged in the TV after replacing the 400V cap and the fuse... Switched it on and nothing happened... Tested the fuse and it was blown. So for the past three hours I've been going through the components trying to test them...
I've found two diodes that are shorted. I'll see if I can find replacements.
Old 07-25-2012, 08:43 PM   #24
ben7
City & State: Trenton, NJ
My Country: USA
Line Voltage: 240v-120v 60Hz 200A service drop
Did you check the bridge rectifier? that could have gone bad and caused the capacitor to blowup.
__________________
Hi-pot test: FAIL
ben7 is offline   Reply With Quote
Old 07-25-2012, 08:52 PM   #25
JonathanAnon
My Country: Ireland
The PS is a Vestel as was suggested by some sharp eyed person earlier.. It's a 17IPS15-4, and they put in rectifying diodes, with no BR. It is two of the rectifying diodes that are blown. D801 and D802 (both RL207 ) in the following document. The rest of the diodes seem fine.
http://elektrotanya.com/vestel_17ips.../download.html
Old 07-27-2012, 11:08 AM   #26
JonathanAnon
My Country: Ireland
Stuff arrived for this today, fuses and 400V cap. Have to order those diodes as well I think, nothing similar here.. Closest I can get is this IN4007 diode which I took from the rectifier of another piece of electrical equipment... but it's only 1A.. everything else I have here has a bridge rectifier, not the individual diodes.
Old 07-27-2012, 02:27 PM   #27
ben7
My Country: USA
Got any scrapped PC power supply boards? You can salvage a bridge rectifier off one of them.
And most likely I think the 1A diodes won't cut it.
Old 07-27-2012, 02:47 PM   #28
momaka
momaka's Avatar
City & State: VA
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Student Tech
That should be fine for testing purposes, as long as it has the proper ratings (2A and at least 400V reverse blocking voltage). Just make sure you wire it right ( + to +, - to -, and the two ~/AC lines to AC).
The 1A diodes may also work for testing. Granted you're in Ireland, you have 230 VAC mains. Unless that power supply is to provide more than 230 W, the 1A diodes should be fine. However, the only problem that might arise is that those diodes may blow up during the initial plug-in due to the large current spike. But you can get around that - just remove the fuse and connect a regular household light bulb to it instead. If there isn't a problem, the light bulb will flash then turn off and the power supply should be outputting the proper voltages. If there is a problem, the light bulb will stay lit - in that case, don't keep power connected to the power supply too long.
You can use that light bulb trick even when the new parts arrive. In fact, this is a very good method to save you from blowing parts if something is wrong.
Old 07-27-2012, 03:45 PM   #29
JonathanAnon
My Country: Ireland
Got any scrapped PC power supply boards? You can salvage a bridge rectifier off one of them. And most likely I think the 1A diodes won't cut it.
I have both a 20 pin and a 24 pin ATX power supply here and both have the rectifier as a single unit.
Quote:
Yeah I was thinking about trying to work in a bridge rectifier as a test, but I'm yet to fix my first screen ( ) so I'm not brave enough yet.
I'm think I'm just gonna order the new diodes rather than risk trying the 1A.. I was looking online have these in my basket 1N5408 ... Just have to process the order. ..
I will definitely be using the bulb trick though, as after replacing the diodes I will have replaced.... - Main filter cap. - fuse - two diodes... So there could very easily be something else blown.
Old 07-28-2012, 10:35 AM   #30
momaka
momaka's Avatar
City & State: VA
My Country: U.S.A.
I'm a: Student Tech
Ah yes, I know that feeling very well . First time I fixed a monitor (it was just 4 bad caps), I had it plugged in a extension cord with an ON/OFF switch and I was wearing safety goggles and had a fire extinguisher next to me. Had the room all quiet too in case something went wrong so I could hear it.
And now I pretty much just plug things in. Only if I've done something very risky then I would use the extension cord.
The safety goggles are the only thing I still won't take off. But I don't think I am over-protective here - electrolytic caps installed in reverse will pop/burst. Even worse, the monitor may appear to work but it won't be until a few seconds after that they'll pop.
With the light bulb in place of the fuse, the only disappointing thing that could happen is that you won't get exciting fireworks if something was wrong. Instead, you'll just get a lit bulb. *boring*
The only exception to that is electrolytic caps installed in reverse.
Old 07-28-2012, 11:51 AM   #31
JonathanAnon
My Country: Ireland
Haha, that's my most important piece of equipment. Only had one bang so far, when I cleverly replaced a fuse in a Dell Monitor with a jump wire.... Pity really cos I reckon it was an easy fix if I'd just waited, got another fuse (to prove that it wasnt actually just a worn fuse causing the problem), and then start to troubleshoot it properly... And that's exactly what I DONT want to do this time..
Old 08-01-2012, 05:56 AM   #32
JonathanAnon
My Country: Ireland
Wohooooooo... it's alive...
My supplier didnt have 2amp diodes, so I ordered 3amps... I read somewhere that even though there are only two that have shorted, it's best practice to replace all four rectifiers... which was a bit of a job given that the 3A were considerably bigger, but managed to squeeze them in by temporarily removing the inductor. Fitted quite snugly in the end..
Replaced the 400v filter cap with the new one, didnt bother with the bulb trick as I ordered a stack of those T3.25A 250VAC fuses... Put it all back together, and here's badcaps on my working screen.
Thanks for the help :-)
Old 08-01-2012, 06:15 AM   #33
ben7
My Country: USA
Good job bro!
What brand capacitor did you use as a replacement?
Old 08-01-2012, 06:49 AM   #34
JonathanAnon
My Country: Ireland
This was a tricky one as the cap in the original was a low profile. One of the electronics providers here didnt even have a size compatible cap.
This is the one that I went with
http://radionics.rs-online.com/web/p/aluminium/7529511/
Nichicon.. Doesnt sound like a name that would be synonymous with "reliability" does it.. .. but it was cheap. I didnt want to buy anything more expensive in case there were other issues with the screen.
Old 08-01-2012, 06:51 AM   #35
ben7
My Country: USA
Good choice there!
Old 08-03-2012, 03:49 PM   #36
momaka
momaka's Avatar
City & State: VA
My Country: U.S.A.
I'm a: Student Tech
Congrats, I'm glad you got it working!
Even if you ordered extra fuses, the light bulb trick is still a very good idea. If there was a fault in the power supply, those components you replaced could have blown again and maybe even more.
Reason why is because those line input fuses are *usually* the last ones to blow - i.e. they blow out only when there is a serious failure elsewhere in the PSU. They are there for protection against fire, not protection of the components in the PSU. The light bulb on the other hand protects the PSU components (at least for a short amount of time).
Other than some problems with their HM and HN series that have now been corrected (only HM and HN series manufactured between 2001 and 2004 were affected), Nichicon is a very very reliable brand.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2013
Powered by vBulletin ®
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
