Thread Tools | Display Modes |
#1 |
Fuhjyyu Killer
City & State: Behind a soldering iron
My Country: New Zealand
Line Voltage: 230V AC 50Hz
A couple of days ago I turned my old Athlon 64 machine on and soon after power-on I heard a loud clicking noise.
It sounded very much like something knocking against fan blades, so I disconnected the case fan, put my finger on the CPU fan and a pencil in the PSU fan. No, the noise still happened. It seemed to be coming from the PSU itself. The PC was running 'perfectly' but as the PSU seemed to be the problem I immediately turned it off. I disconnected the PSU and powered it up with a jumper. It still made the clicking just not as much and maybe quieter. I found the higher the load, the faster and louder the clicking. Seems very odd that the PSU still runs while making such an 'bad' noise! I searched the forum and found a similar problem posted here: http://www.badcaps.net/forum/showthread.php?p=250827 I also got this response: But I want to start a separate thread here to avoid confusion. So, where is the PFC circuit and what kind of diode am I looking for?
__________________
"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous" |
#2 |
City & State: Prague, 50°4'52.22"N, 14°23'30.45"E
My Country: CZ
Line Voltage: 230 V/50 Hz
I'm a: Knowledge Seeker
PFC is usually on the primary side, either on separate heatsink, or with switching transistors.
__________________
#3 | |
City & State: Trenton, NJ
My Country: USA
Line Voltage: 240v-120v 60Hz 200A service drop
Quote:
It will help if you temporarily remove the primary caps to get a better view behind them.
__________________
Hi-pot test: FAIL |
#4 |
Unknown
City & State: North Coast, NSW
My Country: Australia
Line Voltage: 240V 50Hz
I'm a: Professional Tech
It looks like a transistor, but has two legs. In this picture, it's the part to the far right (the other two parts are the PFC transistors)
__________________
I love putting bad caps and flat batteries in fire and watching them explode!! Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro. Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro. 2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod Last edited by c_hegge; 07-12-2012 at 07:33 PM.. |
#5 |
Fuhjyyu Killer
Will have a look and post photos |
#6 |
My Country: USA
#7 |
Unknown
OK, Fixed. I attached it (it works here, though)
#8 |
My Country: USA
Also there should be a high power low ohm resistor for the current sense in the pfc circuit, you might want to check that. If its value has gone up it could fool the control circuit into thinking there is a short circuit.
#9 |
My Country: CZ
Wouldn't it think its shorted when the resistance would go down?
#10 | |
My Country: USA
Quote:
It uses a resistor to measure the current; the circuitry measures the current by measuring the voltage across the resistor. In fact, it wouldn't think its shorted when its a very low resistance, then it is possible for the mosfets to blow! In the control circuitry there is a pre-defined trip voltage. Say the power supply primary has a max power of 100w. With a mains voltage of 120vac, that would be rectified into DC, around 165v. The max load of 100w with a supplied voltage of 165v would draw about 0.6A. We use E=IR to find the resistance of the current sense resistor that we need. The voltage we want to trigger the overload at is 1v. 1v = 0.6A * R, so, R = 1.666. As the current goes to about 0.6A, the voltage across the current sense resistor will be about 1v. Then the protection circuit will kick in. But, say if the resistors resistance increased to 3 ohms. Finding the new trip current: 1v = I * 3ohm so, I = 0.333A That means that at only 0.333A, there would be 1v across the resistor, making the overload protection trip prematurely! The protection circuitry would think that there was an overload, but the power draw of the psu was really only around 54 watts! Edit: and some psu's with PFC will actually work without the pfc running, but of course it will have a bad power factor. Last edited by ben7; 07-12-2012 at 08:06 PM.. |
#11 |
My Country: CZ
Didn't know how the resistor is used in there before, thanks
#12 |
My Country: USA
#13 | |
Fuhjyyu Killer
I got the thing open and figured out how to extract the board from the case...
I believe I've found the PFC diode, an I.R. HFA08TB60 - hidden behind the main capacitor, the PFC coil, and a little sub-board (The PFC control circuitry??) - see photo Quote:
There's a large (~1 watt size) resistor hidden under the primary-side heatsink just behind the HFA08TB60. Coding seems to be Brown-Orange-Silver-Gold-Green which doesn't match up with any chart I know - what value do you suppose it should be? EDIT: Totally missed another, larger resistor just below the PFC coil. Code is Orange-Blue-White-Gold-Green. What should I be testing\checking the diode for? Last edited by Agent24; 07-24-2012 at 06:57 PM.. |
#14 |
My Country: CZ
Short or partial-open. Use diode tester, what does it read in both directions? If I am nto mistaken, ordinary diode should read arround 300 ohm minimum.
#15 |
Fuhjyyu Killer
Going by the datasheet this thing is a bit more interesting than an ordinary diode... that said...
Diode check on multimeter says nothing in reverse bias and "448" in forward bias. Resistance test says infinite in reverse and 530k Ohm in forward. A standard 1N4004 shows "587" on the diode test and 618k Ohm on resistance. (forward bias) I do believe though that some faulty semiconductors will appear fine on a tester but fail in-circuit because of the higher working voltages. How to test that I am not sure. The resistors both measure very low values: * Brown-Orange-Silver-Gold-Green reads as 0.12 Ohm * Orange-Blue-White-Gold-Green reads as 0.03 Ohm |
#16 |
My Country: CZ
It is more or less typical ultrafast to me…
The first resistor looks like non-standard 0,13 ohm. Silver seems to act like ×0,01. The second is 36.9 ohms, ± .5%, according to calculator. Last edited by Behemot; 07-24-2012 at 08:02 PM.. |
#17 |
My Country: USA
I think the same. It's probably good.
The BR-OR-SI-GD-GR resistor is supposed to be a 0.13 ohm 5%. The OR-BL-WT-GD-GR resistor is supposed to be a 36.9 ohm 0.5%.!? This will help with those odd 4 and 5 band resistors Last edited by ben7; 07-24-2012 at 08:09 PM.. |
#18 |
Fuhjyyu Killer
That second resistor (actually R14 on the board) is an oddly, very specific value... and shorted too?
Maybe it's supposed to be 0.0369 ohms 0.5%... no, that probably makes even less sense. Even if that is the case.. where the heck do I get something that specific.. and WHY does it even need something that specific? Maybe it's time to draw out a schematic and try to figure out what that resistor does... Probably time to let you all in on a little secret... I actually have another Liberty 400 lying around... it was my friends and it blew a hole in a MOSFET. I didn't go any further than noticing that (and suspected the brown glue of death) but I guess I could have a look at its R14 resistor and see if it's the same.. of course it may well have had a similar problem, so that might be a waste of time. Aside from the resistor, could there be anything else that's easy to check? |
#19 |
My Country: CZ
The marking should be right, we used two independent calculators. If you won't find exactly same, you can always buy 33ohm plus 3,9ohm in series, you should easily get these two.
#20 |
My Country: USA
Try measuring the resistance of it the other way around.
Also, what is this resistor connected to? |
| Thread Tools | |
| Display Modes | |
