Thread Tools | Display Modes |
#1 |
Hi
I have a Precision 650 sitting here that is circling the drain. I had two of these before and fixed one with a capacitor kit from here. The other one it looked as if someone had tried recapping before and they may have damaged something. The current problem is it was slow. Then it started with the BSOD, Then it would even BSOD trying a windows re-install. Now it shows the Dell logo and that is it. I do not see any obviously bad capacitors. Should I go ahead and order another cap kit from here or am I wasting my time and money. Or another solution? Thank You Roger |
#2 |
City & State: Springfield, Vermont
My Country: USA
Line Voltage: 122-125V 61-62.5 Hz
I'm a: Knowledge Seeker
Could be HDD failure.
__________________
Asus Maximus II Gene Core 2 Duo E8400 @ 3.6 Ghz 2 GB A-Data PC2-6400 DDR2 SDRAM @450 Mhz eVGA GeForce 9500GT (rthdribl stable) Fortron FSP500-60GLN(80) 500W PSU Windows XP Pro x64 SP2 "There's nothing more unattractive than a chick smoking a cigarette" -Topcat "Don't eat yellow snow!" -Salem "did I see a chair fly? I think I did! Time for popcorn!" -ratdude747 |
#3 |
Radioactive
City & State: tehas
My Country: US
Line Voltage: 120VAC 60Hz
I'm a: Professional Tech
yeah that screams HDD failure
sometimes when the START to go corruption begins, causing random errors, then it gets worse and worse, till the bios locks up trying to detect it |
#4 |
Unfortunately not the Hard drive. I unplugged the two and plugged in a known good one. It still ended up with the Dell boot device menu being the last thing that was displayed.
Thanks for the ideas.TB |
#5 |
Radioactive
City & State: tehas
My Country: US
have you tried disconnecting EVERYTHING but the the PSU and front panel?
also, be sure there isn't a heat issue here, sometimes P4's will clock themselfs down if they get too hot, giving the appearence of being too slow. reseat the heatsink, make sure the fan is spinning and it has good airflow |
#6 |
City & State: Trenton, NJ
My Country: USA
Line Voltage: 240v-120v 60Hz 200A service drop
Could be the new caps are crap and letting lots of ripple through. Do you see any broken traces?
__________________
Hi-pot test: FAIL |
| Thread Tools | |
| Display Modes | |
