Badcaps.net Forum
Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Power Supply Design and Troubleshooting
Register FAQ Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 05-11-2012, 01:12 AM   #581
japlytic
japlytic's Avatar
City & State: Rockhampton, Queensland, Australia
My Country: Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
Default Re: Power supply build quality pictorial. part 2
Microsoft Xbox 360 (Hipro HP-AW175EF3P)
3x 2200uF 16V Chemi-Con KZE with one 1000uF 16V Chemi-Con KY.
1200uF 6.3V Rubycon ZL and 470uF 10V LTEC LZF on +5VSB before output MOSFET.
180uF 420V Elite GM on primary side.
2x STP11NK50 primary side MOSFETs in push-pull configuration.
2x STPS3045CW rectifiers in parallel for +12V 14.2A output.
A fan is fitted inside this unit (never saw a "brick" style power supply with a fan before!)
__________________
japlytic is offline   Reply With Quote
Old 05-11-2012, 02:31 AM   #582
Behemot
Behemot's Avatar
City & State: Prague, 50°4'52.22"N, 14°23'30.45"E
My Country: CZ
Line Voltage: 230 V/50 Hz
I'm a: Knowledge Seeker
Quote:
You haven't seen my brick mode than:-D Not that it helped to solve the problem, but…now I believe it runs with greater efficiency and can even provide slightly higher output power (since rectifiers do not run on like 100 °C ).
__________________
Behemot is offline   Reply With Quote
Old 05-11-2012, 05:32 PM   #583
momaka
momaka's Avatar
City & State: VA
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Student Tech
How did you get yours opened that far? Or did yours look like that once you opened the plastic case?
I have a dead Lite-On built Xbox 360 brick that I can't fully open since it has thick metal EMI shields soldered all around it. It's the 203W version.
Yes, they indeed have a tiny fan inside. I can hear it whirl when I jump-start my other working Xbox 360 power brick.
Old 05-12-2012, 09:50 AM   #584
Jooo
City & State: JKL
My Country: Finland
I'm a: Hobbyist Tech
HP 365W proprietary PSU
Jooo is offline   Reply With Quote
Old 05-13-2012, 06:19 AM   #585
ben7
City & State: Trenton, NJ
My Country: USA
Line Voltage: 240v-120v 60Hz 200A service drop
Quote:
Awesome! And look! A TOP244 on the 5V standby!
Atleast the caps are semi-decent in there.
-Ben
__________________
Hi-pot test: FAIL
ben7 is offline   Reply With Quote
Old 05-13-2012, 08:29 AM   #586
ncovert
ncovert's Avatar
City & State: Pennsylvania
My Country: USA
Line Voltage: 116.9V 60hz
I'm a: Student Tech
Hipro HP-P150CLXA6 Rev: 02 150W ATX power supply.
Matsushita primary caps, G-Luxon secondaries, bridge rectifier and input filtering. Another PSU with the fan blowing air into the PC case, just like the Lead Year one I posted, except it was from 1997, while this Hipro is from '99.
__________________
ncovert is offline   Reply With Quote
Old 05-15-2012, 02:23 AM   #587
Wester547
Badcaps User
City & State: CA.
My Country: USA.
Line Voltage: 120VAC 60Hz.
Send a message via AIM to Wester547 Send a message via MSN to Wester547 Send a message via Skype™ to Wester547
^ Hipro have done better.
I have this power supply (these images aren't mine) but I'm wondering if the Hipro below can do 300W in earnest (it's a HP-P3527F3 that came with a dead eMachine T6536 I used to have; better than coming with a Bestec, I suppose)? I don't think it has a PFC. It only has two Teapo 470uF/200v capacitors on the primaries rated at 85C.
Can it do what the label says?
Or is it more like 280W continuous, 300W max?
I see lots of Teapos in there otherwise. It's not easy to tell from the provided picture but does anyone know what else is in there cap-wise (if you click on the last image you can still zoom in more)? Does this look like a well designed PSU or have Hipro done infinitely better and is this more like a Huntkey or Bestec?
EDIT: Thanks Scenic and Behemot.
Wester547 is offline   Reply With Quote
Old 05-15-2012, 02:57 AM   #588
Behemot
Behemot's Avatar
My Country: CZ
Yes, it can. The remaining 20 W is for +5 V SB, -5 V and -12 V
Last image does not show.
Old 05-15-2012, 03:05 AM   #589
Scenic
o.O
Scenic's Avatar
City & State: Duisburg
My Country: Germany
Line Voltage: 230VAC 50Hz
reuploaded the 2nd pic to my webspace, as zol.com.cn has a hotlinking protection in place..
http://bambooz.pytalhost.net/badcaps/HP-P3527F3.jpg
Scenic is offline   Reply With Quote
Old 05-25-2012, 01:48 PM   #590
ncovert
ncovert's Avatar
My Country: USA
I'm a: Student Tech
Got some more units in today. These are PSU's pulled from DVR/TiVo boxes.
3Y Power Technology CP-1074 from a DirecTV DVR R10 (made in 2005). 4 diodes, but input filtering. UCC primary cap (330uf), and a mix of Ltec's and Teapo's on the secondary.
Voltages and currents:
+3.4V 2A
+5V 2.275A
+7.5V 0.75A
+12V 2.5A
Max output 54W
You can see that I didn't take it out of the case, because I was lazy. But I did with the one below (it's easier to do).
AUTEC UPS61-1004-T from a Philips HDR212 (made in 2000). Bridge rectifier and input filtering. Hitachi HP3 primary cap (220uf), and UCC secondaries.
+3.3V 4A
+5V 2A
+12V 3A
+32V 5mA (no, I didn't mean 5A)
No labelled total output
Old 05-25-2012, 02:02 PM   #591
Behemot
Behemot's Avatar
My Country: CZ
Are those Chemi-Cons or Teapos?
Old 05-25-2012, 06:20 PM   #592
ncovert
ncovert's Avatar
My Country: USA
I'm a: Student Tech
On which one and primary or secondary?
Old 05-25-2012, 06:27 PM   #593
Behemot
Behemot's Avatar
My Country: CZ
Those brown of course:-) Seconds secondary.
Old 05-25-2012, 06:33 PM   #594
ncovert
ncovert's Avatar
My Country: USA
I'm a: Student Tech
Quote:
Chemi-con.
Old 05-25-2012, 06:53 PM   #595
c_hegge
Unknown
c_hegge's Avatar
City & State: North Coast, NSW
Line Voltage: 240V 50Hz
I'm a: Professional Tech
Yup. Remember, Teapo are usually green and have small bars in the vent stamps.
__________________
Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro.
Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro.
2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod
c_hegge is offline   Reply With Quote
Old 05-25-2012, 07:06 PM   #596
Behemot
Behemot's Avatar
My Country: CZ
Well maybe not Teapo, I don't even remember all those crappy brands, but some look similar. Jamicon maybe? Damn, who gives a poo, change it on sight
Old 05-26-2012, 06:08 AM   #597
ben7
My Country: USA
Got a dusty old compaq oem ATX PSU at school, hopefully I can get a few pics next week, its full of rubycon and NCC
-Ben
Old 06-05-2012, 02:57 PM   #598
Heihachi_73
City & State: Melbourne
Nichicon switching power supply from an older model PlayStation 2 (SCPH-39002), unsurprsingly, all electrolytic caps are from Nichicon as well (the non-electrolytics are Panasonic however).
A "recap" of this PCB:
C003: LS 100µF 400V CE 85°C N0113
C022: VZC3 1µF 50V
C010: PJC3 22µF 35V
C011: VZC4 0.1µF 50V
C012: VZC4 0.1µF 50V
C016: VZC4 0.1µF 50V
C106: VZC3 1µF 50V
C107: VZC4 0.1µF 50V
C102: HDF2 470µF 25V
C103: HDF2 470µF 25V
C104: HDF2 470µF 25V
C105: HDF2 470µF 25V
C108: PJE4 150µF 25V
This PSU was still in working condition when removed from the damaged PS2 (I found this system on the nature strip with a few missing screws and had a broken connector and ribbon cable for the power/reset button). Being an older PS2 though, the DVD drive was probably toast anyway; I have no way of testing it though. I have scavenged the 7V Matsushita fan from it since, so it's no longer complete.
Heihachi_73 is offline   Reply With Quote
Old 06-07-2012, 01:37 AM   #599
momaka
momaka's Avatar
City & State: VA
My Country: U.S.A.
I'm a: Student Tech
Doesn't look like the PS2 used that much power judging by that power supply. The PS3 PSUs are a completely different animal, though. I think I do have 1 somewhere. Will open it when I get to it someday and post pics.
Old 06-07-2012, 05:42 AM   #600
Agent24
Fuhjyyu Killer
Agent24's Avatar
City & State: Behind a soldering iron
My Country: New Zealand
Line Voltage: 230V AC 50Hz
Quote:
Even if the DVD drive is dead you can run backups of games from hard drive if you have the right software. (That's what I do with mine now, the HDD adapter was cheaper than a new laser and loads faster)
__________________
Agent24 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2013
Powered by vBulletin ®
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
