Thread Tools | Display Modes |
#1 |
On my level
As some of you know, due to an unfortunate incident (family problems) i had to sell my scope in November.
I looked around and $300 could buy me a Tek 2235 - however it would've taken about 3 months for me to save that much, and that would be 3 months without buying random parts, and we all know that isn't possible. So, i found a 2x 10MHz National (Panasonic) scope for $106. That should be plenty enough for SMPS work. I used to have a 100MHz Russian-made single channel scope, but i had no use for the bandwidth as it was too low for FM radio and motherboard clocks anyway, and too high for SMPS and audio. I could have used an extra channel instead of the bandwidth, and that's exactly what i'm doing now. Before telling me to check ebay... 1) I lost my credit card. 2) With shipping costs, i'd end up around the same price. Scopes tend to be on the big and heavy side so shipping costs are killer. Also this scope is advertised as being serviced and calibrated, and he has more than 1 for sale, so i believe the calibration part. Picture is attached. The volts/div knob looks like it maxes out at 5v/div so with an x10 probe that would be 50v/div, and with 8 divisions on the vertical this translates to 400 vpp max, but i'll be making my own probes anyway, so no problem making a x20 or or x50 probe if need be. By far more interesting are the numbers on the right side - which although obscured by the angle, logic says they're 50, 20 and 10mV. With a x10 probe that's a minimum of 100mV/div - the scope i used to have had a 5mV/div setting and that was just barely enough for viewing SMPS output ripple with a x10 probe, so this is going to be some trouble. Although, whipping up an amplifier to increase vertical sensitivity shouldn't be too hard. Anyway, i've closed the auction already and got the seller's details. He lives close to me so that was an extra decision point there. I'll probably go pick it up tomorrow evening. Oh wait, make that today since it's 2:30AM already.
__________________
A working TV? How boring! Last edited by Th3_uN1Qu3; 04-01-2012 at 05:34 PM.. |
#2 |
Mac Enthusiast
City & State: Chicago! Run 4 your Life!
My Country: USA
Line Voltage: 120VAC 60hz
I'm a: Knowledge Seeker
Congratulations!
I thought that the stated bandwidth of an oscilloscope was kind of a "minimum" bandwidth rather than an absolute one. That is, 100mhz scopes are often used for FM in the US which goes to 108mhz, just so long as the probes are capable and maybe you don't mind estimating fractions of a division on the graticule. Or so I've been told. Maybe your 10mhz one can go a bit higher?
__________________
The More You Learn The Less You Know! Last edited by KeriJane; 04-02-2012 at 11:02 AM.. |
#3 |
On my level
Stated bandwidth is -3dB point. If you go higher, the signal gets attenuated more. If the signal is a square wave and you don't get at least 5 harmonics it won't look like a square wave anymore, so for a square wave signal of frequency f you need at least 5*f bandwidth on your scope to get a reasonable representation. For a sine wave, you can see up to the rated bandwidth, but it gets attenuated more and more the further you go.
There's an additional issue in that the timebase is usually correlated to the maximum bandwidth, so the signal would be so squished that you couldn't make much of it anyway. A 100MHz scope isn't enough for checking the output of an FM transmitter, i tried that myself with the one i used to have. Anyway, i ran into some trouble and couldn't pick it up today, i'll tell you what happened some other time, as i had a really hard day. |
#4 |
City & State: Trenton, NJ
My Country: USA
Line Voltage: 240v-120v 60Hz 200A service drop
Hooray! then you can also work on your ESR meter project too!
-Ben
__________________
Hi-pot test: FAIL |
#5 |
City & State: University of Leeds (MEng ElecEng undergrad)
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
I've got a test equipment store about 10 miles from me. I've bought from them:
- Tagasaki 0-30V 0-3A PSU - £30 - HP 54501A scope (100 MHz) plus one probe - £150 - Gould OS300 scope (20 Mhz) plus one probe - £60 They have towers of scopes where I went, sadly most out of my price range, I saved up my hard earned TV repair money to buy these things.
__________________
** Begin Signature ** I fix TVs and electronics as a hobby and to save nice things from the dump. 40 LCD TVs, 4 monitors, 13 plasma TVs, and a 6.1 system! Free service manuals database: http://www.tgohome.com/ServiceManuals - Have a manual? Need a manual? Please PM me. I have successfully fixed (from best --> worst build quality): 3 Panasonic Plasmas, 1 Yamaha HTS, 1 NEC Plasma, 2 Sharp LCDs, 2 Toshiba LCDs, 5 Philips Plasma/LCD, 1 Hitachi Plasma, 5 LG LCD/Plasma, 10 Samsung LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Dell LCD, 1 iiyama LCD, 1 Logik LCD, 5 Bush LCD, 10 Vestel LCDs [Please do not PM me for help: I am a busy student, and we prefer input from all sides on this forum.] |
#6 |
City & State: San Jose, CA
My Country: USA, Unsure of Planet
Line Voltage: 120VAC, 60Hz & 115VAC, 400Hz
I'm a: Professional Tech
Triggered, very cool! Keep in mind that non-sinusoidal signals have significant harmonic frequency components, so above ~1MHz square wave signal edges will look sloppier than they really are. OTOH, you will be able to see signals greater than 10MHz, just not to scale. A signal generator putting out a sine wave signal and a 100MHz (or better) scope can help you plot out what your scope can do above 10MHz.
__________________
PeteS in CA Republican Operative discussion forums Where might is right There is no right. - Sophocles in "Antigone" **************************** All that is gold does not glitter, Not all those who wander are lost; - J.R.R. Tolkien, The Fellowship of the Ring **************************** To kill personal responsibility, initiative or success, punish it by taxing it. To encourage irresponsibility, improvidence, dependence and failure, reward it by subsidizing it. |
#7 |
On my level
Alright, picked it up today. It wasn't that close to where i live actually, thankfully there's the subway. The seller was a funny old man which owns a TV repair shop - the kind i used to see when i was little, with tons of equipment all over the place. He had everything from CRTs to huge plasma TVs, stereos, receivers, and dozens of speakers.
He told me that he'd have work for me if i lived closer... I guess i made a good first impression. He also gave me a few tips that will come in useful. As about the scope, i got a pleasant surprise: it's pretty small and portable. And no noisy cooling fan either, it doesn't use one. |
#8 |
On my level
I played with it some more and here's my conclusions.
The good:
The bad:
I played the youscope demo on it and it looked great, only for some reason it appeared upside down. Anyway, for now, i'm happy with it. Gotta build a couple more probes. I'll check the caps in it these days, i have the feeling a recap wouldn't hurt. |
#9 |
If it's more than 10 years old, recapping would be a good idea. Look for date codes on caps and ICs.
#10 |
On my level
If it's got ICs, they're not in view.
It seems like a pretty simple (and cheap) design. It even has a large trimpot in plain sight to adjust the amplitude of the internal calibrator signal. So that calibrator has officially become entirely useless. Wrong frequency and unknown amplitude. There's a coil around the tube that i have no idea what it does, as IIRC oscilloscopes used electrostatic deflection. Maybe degaussing or magnetic field compensation? It has a resistance of about 570 ohms and has 0.783v DC on it when the scope is on. No AC signal could be detected on it.I still have no idea what's up with the geometry distortion. |
#11 |
Mac Enthusiast
My Country: USA
Maybe it's a delay coil?
Internal calibrators are meant for adjusting the probes. Mine says that it isn't meant as a precision reference. The amplitude and frequency are adjustable on mine... perhaps yours are too? Of course you have to check it with a calibrated scope while adjusting, so maybe a signal generator could help. Have fun! |
#12 |
City & State: Shapleigh Maine
My Country: USA
#13 |
On my level
I know that. You can do it just for show but not more than that... Also, i don't happen to have any crappy little CRTs lying around, just two 21" Trinitrons and there's no way i'd do such a thing to one of them.
#14 |
On my level
And here's a pic of both channels working, checking out the outputs of a SG6105D. That glitch on the other channel when switching shouldn't be there - i'll take a look whether it's still present after the driver transistors. Looks like someone skimped on some filtering on the controller, but it isn't much of a surprise is it?
| Thread Tools | |
| Display Modes | |
