Badcaps.net Forum
Go Back   Badcaps Forums > General Topics > Custom Tweaks, Modifications, and Revisions
Register FAQ Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 09-22-2010, 02:02 PM   #1
shovenose
404 Not Found
shovenose's Avatar
City & State: Fairfax, California
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Forum Junkie
Talking Shoebox-pc
would using either a 1u psu or atx psu (whichever fits better).
intel mini-itx mobo
512mb ram,
40gb ata 3.5" hdd
slim ide cd drive with adapter to normal ide...
and maybe a fan somwhere even though that may not be neccessary (cel 1.1ghz)
__________________
Firefox is named after a fox - WRONG! That orange thing is a Red Panda, not a fox!!
http://www.youtube.com/watch?v=y6GaPkkGZGw
PSU Pr0n
http://www.psudatabase.com/
shovenose is offline   Reply With Quote
Old 09-22-2010, 02:23 PM   #2
weirdlookinguy
City & State: San Diego, CA
Default Re: Shoebox-pc
That sounds like a fun project. Maybe build a frame out of balsa wood that fits inside a shoebox?
Computer components, some thin balsa wood, wood glue, maybe some hot glue. It sounds very doable.
The shoebox WILL BE a vans box, right? None of this etnies, DC, or converse shit.
weirdlookinguy is offline   Reply With Quote
Old 09-22-2010, 02:40 PM   #3
ratdude747
ratdude747's Avatar
City & State: New Albany, IN
My Country: USA
I'm a: Student Tech
Send a message via Yahoo to ratdude747 Send a message via Skype™ to ratdude747
i had that idea once... never got around to it...
__________________
(Insert signature here)
ratdude747 is offline   Reply With Quote
Old 09-22-2010, 02:51 PM   #4
AudioCraZ
City & State: Bakersfield, CA
Send a message via ICQ to AudioCraZ
Just make sure you have a good metal backplate, and ground it to the power supply. All those metal rings on the motherboard where you put the screws to mount the board down are grounding points.
AudioCraZ is offline   Reply With Quote
Old 09-22-2010, 03:01 PM   #5
c_hegge
Unknown
c_hegge's Avatar
City & State: North Coast, NSW
My Country: Australia
Line Voltage: 240V 50Hz
I'm a: Professional Tech
Souds similar to something I did here: http://www.badcaps.net/forum/showthread.php?t=8275
Only, this will be smaller and have no monitor
__________________
Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro.
Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro.
2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod
c_hegge is offline   Reply With Quote
Old 09-22-2010, 03:52 PM   #6
shovenose
404 Not Found
shovenose's Avatar
My Country: USA
I'm a: Forum Junkie
@c_hegge
i read that thats what inspired me
@audriocraz - do i HAVE to do that?
@WLG - itll be a LAKAI SKATE SHOE box and im gonna slap the LAKAI stickers that came with them on the components
Old 09-22-2010, 05:06 PM   #7
ratdude747
ratdude747's Avatar
My Country: USA
I'm a: Student Tech
you really should ground them... you do not NEED to, but you SHOULD.
Old 09-22-2010, 06:37 PM   #8
shovenose
404 Not Found
shovenose's Avatar
My Country: USA
I'm a: Forum Junkie
if its gonna be inside the bow what does it matter? will it catch on fire? what are the risks?
Old 09-22-2010, 06:57 PM   #9
c_hegge
Unknown
c_hegge's Avatar
I didn't ground anything on my briefcase PCs. They work fine. The PSU's case and black wires connect directly to the earth pin on the power point. That grounding should be fine.
Old 09-22-2010, 07:28 PM   #10
shovenose
404 Not Found
shovenose's Avatar
My Country: USA
I'm a: Forum Junkie
ok. anything else i need to look out for?
Old 12-14-2010, 09:09 PM   #11
crepiduse
Just use a 6" lcd and a cigar box with a 12v motherboard micro atx or pico board.
crepiduse is offline   Reply With Quote
Old 09-16-2011, 03:27 PM   #12
nertia
Hi, been lurking around here for a while...
This is my shoebox PC, Tyan motherboard running pfsense firewall for last 18 months or so, silver tape and a degree of origami were used in its construction.
nertia is offline   Reply With Quote
Old 09-16-2011, 06:41 PM   #13
dood
Deputy dood
dood's Avatar
City & State: Berwick, PA
My Country: USA
Line Voltage: 120VAC 60HZ
I'm a: Hardcore Geek
Nice job with the gaffer tape and bailing twine!
I'm about to build a PFSense box from a iDeq barebones cube. Board needs recapping first, though.
What are the specs on your shoebox?
Oh, and welcome to the forum!
__________________
Ludicrous gibs!
dood is offline   Reply With Quote
Old 09-19-2011, 08:34 AM   #14
shovenose
404 Not Found
shovenose's Avatar
My Country: USA
I'm a: Forum Junkie
Oops...mine worked out for a while and worked pretty well...but I took it apart for the move and I needed the psu for something...also tried a toaster oven PC but that didn't work at all...
Old 09-19-2011, 09:13 AM   #15
dood
Deputy dood
dood's Avatar
My Country: USA
Quote:
Problems overheating?
Old 09-23-2011, 07:00 PM   #16
delaware74b
delaware74b's Avatar
City & State: Delaware
My Country: USA
Line Voltage: 480VAC 60Hz or Less
I'm a: Knowledge Seeker
No worse than one of those Dell or HP Prescott-based SFF mini-ovens
delaware74b is offline   Reply With Quote
Old 09-23-2011, 07:14 PM   #17
shovenose
404 Not Found
shovenose's Avatar
My Country: USA
I'm a: Forum Junkie
Quote:
No just the shit didn't fit...
Old 03-30-2012, 01:24 PM   #18
NormanSaxon86
City & State: Shapleigh Maine
My Country: USA
I always like PC built into Ammo boxes I think that if you want a strong compact case you can't go wrong some are the same size at a shoe box.
My thoughts Make sure you look for a mobo that can be upgraded in to future I would go for a micro atx because they still have the same parts at the full atx just smaller.
NormanSaxon86 is offline   Reply With Quote
Old 03-30-2012, 01:25 PM   #19
NormanSaxon86
My Country: USA
You will need to have good air flow a blow hole and at least 2 fans more if you OC.
Old 03-31-2012, 02:10 PM   #20
NormanSaxon86
My Country: USA
here is a cool idea a safe pc, right you could keep your parts all lock in your computer. In case you think you might get them jacked.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2013
Powered by vBulletin ®
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
