Badcaps.net Forum
Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Power Supply Design and Troubleshooting
Register FAQ Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 08-25-2011, 03:58 AM   #321
japlytic
japlytic's Avatar
City & State: Rockhampton, Queensland, Australia
My Country: Australia
Line Voltage: 240VAC 50Hz
I'm a: Hobbyist
Default Re: Power supply build quality pictorial. part 2
Infinity ATX P4-400W
Cheng 470uF 200V primary units.
Non-approved Y-class units .
13007 primary switchers.
FSDM311 +5VSB switcher.
HS8108B control IC.
1000uF 10V Bor Hurng before and after +5VSB inductor.
1000uF 10V Bor Hurng on +3.3 and +5V rails.
1000uF 16V Bor Hurng on +12V rail.
220uF 16V Bor Hurng on -12V rail.
S10C45C rectifier on +3.3V rail (16A).
S16C45C rectifier on +5V rail (24A).
S12C20C rectifier on +12V rail (16A).
KBP307C input rectifier.
__________________
japlytic is offline   Reply With Quote
Old 08-27-2011, 02:22 AM   #322
pdavid
My Country: Hungary
Line Voltage: 230V/50Hz
Two ATX psus.
Compaq 250W (Lite-On) Veeeery heavy
680uf 200V ????
Secondary has Rubycons...
Can't see much really
Ever-Power 235W (Channel Well)
2x 330uf 200V Teapo
2x 1000uf 10V Capxon
2x 1650 16V Fuhjyyu
Oh well...
4 Amp rect. bridge
2x 13007
2x P40NE mosfets
1x D83-004 Schottky
Both working good. They were just dusty.
pdavid is offline   Reply With Quote
Old 08-27-2011, 06:19 AM   #323
everell
everell's Avatar
City & State: Williamsburg, Virginia
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
The EverPower is a ChannelWell AT power supply with add on 5vsb board to make it a ATX power supply. They also did this for Antec. Here are some pictures of an Antec ATX power supply made by ChannelWell with the 5vsb retrofit board.
everell is offline   Reply With Quote
Old 08-27-2011, 09:24 AM   #324
pdavid
My Country: Hungary
When I opened up the EverPower I remembered other psus having similar add on 5vsb circuits. It seems the KA393 gets power from a small board that says ps-on.
I haven't looked too much into the 250W Compaq. This one looks way more intersting with it's quaint buildup.
Old 08-27-2011, 10:19 AM   #325
mariushm
City & State: Romania
Line Voltage: 230VAC 50Hz
This is a power supply I have nice memories of - well not really this psu but the computer it came from, a HP Vectra with a 486/66 Mhz that was gifted to me so that I could have a computer in the first year of university.
As you can see from the pictures, it's a Delta, pretty much plain AT... 5v@13.5A, 12v@4.5A with a max output of 100w
Minibea fan 12v@0.3A , can't tell the actual mosfets/diodes because I'd have to desolder the inpu wires or remove the heatsinks but the capacitors are all quality :
Rubycon 270uF 400v on the primary,
1 United Chemi Con or Nippon Chemi Con (it's that particular logo on them) sxe 2200uF 16v and 2 2200uF 10v
Rubycon YXB 1000uF 10v on secondary,
some SXE 2200uF 10v
a few small KME 10uF 50v, a 220uF 3.5v
a lonely taicon 1000uf 16v on the 12v line and a few small ones around the center of the pcb, 0.47uf, 47uF
It still worked fine about 3-4 years ago but it should still work great now.. For something made in '96 it still looks good, nothing bulging or leaking...
I'd like to know the topology but I assume it's a half bridge or something before that...
mariushm is offline   Reply With Quote
Old 08-29-2011, 06:07 AM   #326
mariushm
Recently had to open up my Samsung ML-1710P printer so I thought about doing some power supply snapshots.
center IC is str g6353 ... the one on the left I can't reach
big cap is Lelon 400v 100uF LS series
black cap on the right si a Samwha 1000uF 16v (s3c) , green one is a Lelon 1000uF 35v RGA series, blue one is a Lelon but too lazy to bend it and read the value
Don't see the need to recap it as it works fine... well as fine as a drum with 10k pages lifetime works after 15k pages printed on it (there's some toner graying out a few millimeters on the right side of the pages, like you would see on some fax machines)
Old 08-30-2011, 01:28 PM   #327
momaka
momaka's Avatar
City & State: VA
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Student Tech
Quote:
Hard to say exactly... there's a small transformer that could be the driver if this is a half-bridge design. But there's also only one mains cap, so this could also be a MOSFET-based single-transistor forward design (with IC1 being the PWM controller and IC2 and IC3 providing feedback to primary). Most likely it's a single-transistor forward. How many transistors are there on the primary side, and what are the various IC?
Old 09-03-2011, 04:57 AM   #328
japlytic
japlytic's Avatar
I'm a: Hobbyist
SLB ATX-300W
All electrolytics are ChengX.
Half of the bridge rectifier are 2A units, with the other two 3A units.
1000uF 10V before +5VSB inductor and 470uF 10V after it.
2200uF 10V before and after +3.3V inductor.
2200uF 10V before and after +5V inductor.
2200uF 25V before +12V inductor and 470uF 16V after it.
470uF 10V on -5V rail.
470uF 16V on -12V rail.
2SK2141 primary side MOSFET (this is not an old-school style power supply!)
2SC5027 primary side transistor for +5VSB.
SBR2040CT rectifier for +3.3V.
SBL3040PT rectifier for +5V.
MUR10100CT rectifier for +12V .
TD3843 (=UC3843) controller with LP7510 voltage supervisor.
Old 09-03-2011, 05:53 AM   #329
b700029
Banned
Leadman/Powmax!
I like how they used a huge axial diode in a place silkscreened for a tab-mount (but the heatsink was cut too short to reach it)
b700029 is offline   Reply With Quote
Old 09-03-2011, 06:41 AM   #330
Th3_uN1Qu3
On my level
Th3_uN1Qu3's Avatar
City & State: Bucharest
My Country: Romania
I'm a: Student Tech
Send a message via Yahoo to Th3_uN1Qu3
Quote:
You know i was preparing to ask where the TL494 is... But i guess i know why they did it like that - look at that tiny transformer! Also, a currentmode controller makes the thing harder to blow up. That means, motherboard goes out first.
__________________
Quote:
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 09-16-2011, 02:17 AM   #331
japlytic
japlytic's Avatar
I'm a: Hobbyist
Omni PS-ATX 500W
680uF 200V CapXon LP primary units.
3300uF 10V Xunda (bulging) before +3.3V inductor with 1000uF 10V XJ after it.
3300uF 16V Nova on +12V rail.
2200uF 10V XJ before +5V inductor with 3300uF 10V Xunda (bulging) after it.
470uF 16V XJ before and after +5VSB inductor.
470uF 16V XJ on -5V and -12V rails.
MJ13009 primary switchers.
6A 800V bridge rectifier.
SBL3040PT rectifier each for +3.3V and +5V rails.
U20D20C rectifier for +12V.
Old 09-16-2011, 04:07 AM   #332
c_hegge
Unknown
c_hegge's Avatar
City & State: North Coast, NSW
Line Voltage: 240V 50Hz
I'm a: Professional Tech
Another Omni PS-ATX 500W (they are obviously not that consistent with their designs).
680uF 200V Nippon Chemi-Con KMG primary caps
2x 1000uF 10V SD caps on 5v Rail (one before and one after Jumper wire), ST3045CW Schottky.
2x 1000uF 16V <BH> on +12V rail (one before and one after Jumper wire), STTH2002CT rectifier
The 3.3v rail is uses the same parts as the 5v rail (only, it has a PI filter coil)
ST W13009 primary switchers.
6A bridge rectifier.
I have another identical PSU, which I re-capped, added a fan, and replaced the ceased up fan with a CM blue LED fan, this one, on the other hand, I'm just gonna explode.
__________________
Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro.
Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro.
2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod
c_hegge is offline   Reply With Quote
Old 10-05-2011, 01:20 PM   #333
SIDMX
City & State: Tamaulipas
My Country: Mexico
Line Voltage: 115VAC 60Hz
I'm a: Knowledge Seeker
Pixxo Jaguar PW series 600W (K-Mex)
Bridge Rectifier - KBL06 600v-4A
Primary Caps - 2x HEC 560uf-200v
Primary Switchers - 2x MD 13009K 400v-12A
Primary Side Mosfet - CET CEF-02N65D 600v-1.5A
Schottky Rectifier - MOSPEC S30D40CS 40v-30A
Schottky Rectifier - MOSPEC S20C40C 40v-20A
Switch Mode Rectifier - MOSPEC F16C20C 20v-16A
Supervisor+Regulator+PWM - System General SG6105ADZ
Output caps for +3.3v- 2x YC 2200uf-10v
Output caps for +5v - 2x YC 2200uf-10v
Output cap for +12v - Chengx 2200uf-16v
Output cap for -12V - KHC 470uf-16V
There's no way it can do 600W, maybe 400W Max ??, what do you think guys?
SIDMX is offline   Reply With Quote
Old 10-05-2011, 04:21 PM   #334
lti
City & State: Windsor, Colorado
My Country: United States
That looks like a 200W power supply to me.
lti is offline   Reply With Quote
Old 10-05-2011, 06:10 PM   #335
goodpsusearch
City & State: Thessalonik
My Country: Greece
I'm a: Hobbyist
300-350W max
edit: With that transformer I don't think it can make more than 300W...
goodpsusearch is offline   Reply With Quote
Old 10-05-2011, 09:13 PM   #336
momaka
momaka's Avatar
City & State: VA
My Country: U.S.A.
I'm a: Student Tech
Quote:
More like 300W continuous. 350W on a good day. It will do 400W only when it explodes and shorts momentarily before the fuse blows.
I bet you the over-power protection on the SG6105 is set to that as well (about 300W or so).
What do you think guys?
Let's see, here...
60A on the 5v rail with only 1x 30A rectifier? - I don't think so. Maybe peak for 0.1 ns. The 3.3v and 12v rails claiming 36A with 20A and 16A rectifiers respectively is also a complete lie.
What else? - the spacing of the traces on the PCB on the primary side is wrong - it should be much more than that. The transformers are undersized and UL logo is forged (no number).
Old 10-05-2011, 09:36 PM   #337
c_hegge
Unknown
c_hegge's Avatar
It looks very similar to the Rexpower PL400 which I re-built, so the OEM would be KeyMouse. On the PL400, the OPP was set at only 200W. Whether this would be the same or not, I don't know. the only way to find out for sure is put it on a load tester (or send it to me )
EDIT. I do also have a K-Mex branded PW450 unit. It will do up to 350W, but this one isn't quite as beefy.
Old 10-05-2011, 10:04 PM   #338
b700029
Banned
They didn't even bother to change the ratings for the rails with different wattages!
The limiting component here is the primary rectifier, 4A at 120V gives 480W in but with 75% efficiency (typical) that's 360W out. The secondary is good for 400W so the first thing to go will probably be the primary rectifier.
EI-40 transformer is sufficient for a 350W unit, and is even found in some real 400W.
Old 10-06-2011, 05:01 AM   #339
Th3_uN1Qu3
On my level
Th3_uN1Qu3's Avatar
My Country: Romania
I'm a: Student Tech
Quote:
I've heard that a million times. And no, the primary diodes almost never blow even though in theory they are way undersized for the task. None of the power supplies with the "4-diode treatment" tested by Hardware Secrets ever blew the primary rectifiers. It's the primary switchers which almost always give up due to overheating, and the 12v rectifiers sometimes.
Old 10-28-2011, 06:22 PM   #340
goodpsusearch
My Country: Greece
I'm a: Hobbyist
Delta DPS300MB 300W
5vsb = 4.2V
1 bad Capxon GL 1500uF 16V and 1 Ltec 220uF 25V that had high esr
Attached photos with the Capxon removed:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2013
Powered by vBulletin ®
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
