Thread Tools | Display Modes |
#1 |
City & State: N. GA
Hi Guys, I have searched and read but I am not a seasoned technician but do have a Fluke multi-meter and can solder fairly.
I have two displays both being the non REV.02 powered units. I want to state my symptoms and ask a couple if I can. The display turns on for a second and blackens out. I replaced all the caps and they were not bulged. I have done this operation on another display having bulged caps with success. What next? Another display that flickered and blacked out I changed the caps and it seemed fine until I went to adjust it. The brightness was almost maxed so I dimmed it and the left side went darker and she blacked out. I cycle power and it shows for a second only. I cannot get at it to brighten it but why if its bad right? As for the transformers?? Can the be tested on board or do the need to be removed? Thanks, any help would be great.
__________________
GAPI |
#2 | |
City & State: Phoenix, AZ
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist
Quote:
The transformers can be tested while still on the board, of course with power off. Measure the resistance of the secondaries of each transformer. They should match to within 3%. If you are not certain about which pins are for the secondaries, post pictures of the top and bottom of your power supply / inverter. PLEASE use 'Manage Attachments' - below the text entry area. Substituting known good CCFLs (it is not necessary to remove them or the originals from a panel) one at a time can help locate the problem CCFL or wiring. PlainBill
__________________
For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored. Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. |
#3 |
City & State: N. GA
Thanks,
Attached are pics of a duplicate board that hums. Also note the caps in between the transformers are supposed to be 13mm in Dia but the supplier sent me 10mm. Problem? Also a closeup shot of some discoloration on the boards bottom. I did not post the actual board because its still assembled but it is the same part number. The purpose here is hopes for you to help me with the test pins locations, and to show you a second board and ask about the 10mm vs. 13mm. Let me know if if the pics are ok and if you need to look at the actual board. Thanks! |
#4 | |
My Country: USA
I'm a: Hobbyist
Quote:
The critical parameters on replacement caps include capacity - exact match is important, voltage - don't go lower, ESR (impedance at 100Khz) - don't go higher - and physical size - you must be able to get the covers on. A smaller diameter should not be a problem provided the other parameters are met. PlainBill |
#5 |
City & State: N. GA
Fantastic, I'll check them out.
While waiting for you I did some trouble shooting by swapping parts. I have two of these I am trying to make one out of I hope or better. What I ended up with is:
Fun stuff. I'll checking the transformers and perhaps await a link to checking my lamps? Thanks! |
#6 |
My Country: USA
I'm a: Hobbyist
Far and away the best way to test CCFLs is by substitution. Fortunately, most CCFLs use the same pinout. One part of my test kit is a CCFL assembly removed from a monitor. By using that to replace each CCFL in turn, I can identify a defective CCFL without opening the LCD panel. One Unique guy here also modified a power supply / inverter so he can test CCFLs directly.
Each of these are tools. In your case, I would use the inverter / power supply and signal card from the monitor with brightness issues to test the other panel. And vice versa. PlainBill |
| Thread Tools | |
| Display Modes | |
