Thread Tools | Display Modes |
#681 |
Deputy dood
City & State: Berwick, PA
My Country: USA
Line Voltage: 120VAC 60HZ
I'm a: Hardcore Geek
I just bumped up to 8th place on the team!
__________________
Ludicrous gibs! |
#682 |
Deputy dood
My Country: USA
I'll be taking 7th in the next 24 hours (unless daytona fires back up), but then it's a LOOOOONG run to 6th. I need to get a new PC at home to boost my count!
#683 |
City & State: Canterbury
My Country: New Zealand
Line Voltage: 230VAC 50Hz
I'm a: Forum Junkie
I have joined the team
__________________
My pc CPU : AMD PHENOM II x4 @ 3.5Ghz MB : ASUS M4A89TD PRO USB3 RAM : Kingston ValueRAM 16gb DDR3 PSU : Cooler Master 850W Silent Pro GPU : ATI Radeon HD 6850 |
#684 |
Deputy dood
My Country: USA
Awesome! I prefer these stats over the official page - http://folding.extremeoverclocking.c...php?s=&t=49813
What's your username? |
#685 |
I'm a: Forum Junkie
joshnz
Haven't completed a unit yet it's only using 25% of all four cores? |
#686 | |
Deputy dood
My Country: USA
Quote:
Here's a list of the Beta clients - http://folding.stanford.edu/English/DownloadWinOther Assuming you're running Windows, you need to scroll down to find "Windows: V6 Beta SMP2/CPU clients". You also need to register your name to get a passkey - http://folding.stanford.edu/English/FAQ-passkey I'll get you the SMP client config that I use in just a second... |
#687 |
Deputy dood
My Country: USA
Okay, here's my install guide.
Download the client. Create a new folder in your C: drive, and save the EXE there. When you run the EXE, it assumes that the folder that it's in, is where it is to be installed. Run the EXE. User name? - Your Username Team Number - 49813 (for Badcaps) Passkey? - The key you registered Use Proxy? - probably the default of [no], but if you do, enter yes and configure Big units? - I always set this to big Change Advanced Options? - yes Core priority - leave at idle CPU Usage - leave at 100 Disable assembly code - leave at no Pause if battery power - leave at no if desktop, enter yes if laptop (may also want to enter yes if you have a UPS) Checkpoint Interval? - I set this to 5. Limits how much work has to be redone if I reboot the PC Memory to indicate available - Just leave this to the default of max Set -advmethod always? - set to yes; this will get you the most points. Ignore deadlines - default no Machine ID - leave at 1 CPU affinity - no Additional client parameters - enter -smp IP address to bind - leave blank At this point, the client should fire up and download its first packet. You may still see that it's not using all the cores. If that's true, you need to close the client, go back to the install directory, delete your entire work folder, and restart the client. sometimes it takes a "reboot" of sorts to get the right work packet. Any questions, let me know, and happy Folding! |
#688 |
I'm a: Forum Junkie
Full steam ahead. |
#689 |
Deputy dood
My Country: USA
I'll be waiting to see your first WU
#690 |
Deputy dood
My Country: USA
I see you dropped your first WU. Only 600 points, which is pretty low for a SMP Advmethod unit. I think you have to complete a number of advmethod units before you start getting the bonus, though. If it doesn't improve in a few days, we'll have to revisit your config.
#691 |
I'm a: Forum Junkie
I am going to have to review my cooling solution my cpu gets to 52°C.
#692 |
I'm a: Forum Junkie
2 units completed.
#693 | |
Screwed Up Super Moderator
welcome to the fold (yeah...bad pun)
![]() i can't wait for winter.....then i can fire up the heaters again. ![]()
__________________
"Its all about the boom....." Guns kill people like spoons made Rosie O'Donnell fat. We now return you to your regularly scheduled drinking. "Fear accompanies the possibility of death.....calm shepherds its certainty" Quote:
#694 |
Deputy dood
My Country: USA
#695 |
I'm a: Forum Junkie
#696 | |
Deputy dood
My Country: USA
Quote:
The points that I'm returning are from a single PC - Core2Quad 3.0ghz Q9650 |
#697 |
City & State: is in the USA. (Barbecue City)
Ahh, a new user. Yay!
Welcome joshnz |
#698 |
I'm lowering my output due to the overwhelming heat outside. 108 f/ 42 c today.
#699 |
I have been less than consistent lately. I haven't had luck getting the amd64 version of folding to play well with fedora x64 (via the origami script). my two other folders have been operational off and on (a p4 ht 2.8 and a pIII 800mhz).
__________________
(Insert signature here) |
#700 | |
Deputy dood
My Country: USA
Quote:
I don't bother running it on my A64x2 at home, because my GeForce 8600 can outperform it... (I also don't bother running it on the video card, because it slows down all video performance... even just browsing the web). But hey... it's your power and A/C, so you're welcome to keep on chugging! |
| Thread Tools | |
| Display Modes | |
