Badcaps.net Forum
Go Back   Badcaps Forums > Battling the Bad Capacitors > Frequently Asked Questions
Thread Tools Display Modes
Old 07-28-2010, 04:51 PM   #1
AudioCraZ
Send a message via ICQ to AudioCraZ
Default White area on mobo indicates positive?
Ok, I am looking at a Asus A8N-VM CSM Rev 1.10GC, and all of the caps seem to be on backwards... All of the negative stripes on the capasitors are on the "non-white" area. the positive terminal of the capasitor is on the white half..... are they changing somethng?
AudioCraZ is offline   Reply With Quote
Old 07-28-2010, 05:09 PM   #2
Per Hansson
Per Hansson's Avatar
Send a message via ICQ to Per Hansson Send a message via MSN to Per Hansson
Default Re: White area on mobo indicates positive?
They just don't follow the standard...
Install new caps the same way the old caps are (i.e. follow the stripe on the cap, not the marking on the mobo)
__________________
Per Hansson is offline   Reply With Quote
Old 07-28-2010, 05:26 PM   #3
370forlife
Spoot
370forlife's Avatar
Send a message via AIM to 370forlife
Asus did this for some reason on some of their motherboards. Don't know why, they just decided to do something confusing and different.
__________________
370forlife is offline   Reply With Quote
Old 07-28-2010, 06:07 PM   #4
Topcat
Topcat's Avatar
Send a message via ICQ to Topcat Send a message via AIM to Topcat
I always call them "ASS BACKWARD ASUS".....yes the white area on the silkscreen indicates the positive pole for the caps.
__________________
<--- Badcaps.net Owner!!
Badcaps.net Services:
Premade Capacitor Kits
Rubycon Inventory
Samxon Inventory
Polymer Inventory
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 07-28-2010, 07:29 PM   #5
goodpsusearch
Asus... always innovative
lol
goodpsusearch is offline   Reply With Quote
Old 07-29-2010, 06:21 AM   #6
c_hegge
Nut Case
c_hegge's Avatar
Same goes for ASRock. The white side = Positive
__________________
My System: Core 2 E8400 3GHz Overclocked to 3.6GHz (Stock cooler from Pentium D), Gigabyte GA-EP45-DS3L, 4GB Kingston DDR2 800, 250GB Seagate HDD, Samsung DVD RW, ATI Radeon HD3850 512MB, Antec 1200 Case, Vantec ION 620W (Modded and re-capped), Hauppauge TV Tuner, Windows XP Pro.
c_hegge is offline   Reply With Quote
Old 07-29-2010, 06:50 AM   #7
Topcat
Topcat's Avatar
Asustek makes both Asus and ASSrock.....
Old 07-29-2010, 07:53 AM   #8
ratdude747
ratdude747's Avatar
Location: West Lafayette, Indiana, USA... Louisville,KY (when the move is done)
ASSrock... lol!
__________________
(your ad here)
ratdude747 is offline   Reply With Quote
Old 07-29-2010, 03:26 PM   #9
PlainBill
PlainBill's Avatar
I'm laughing about this thread. When I started in electronics the positive lead of the capacitor was marked. The positive lead was also marked on the circuit boards in American designed products. Far from 'doing something different', Asus was doing things the way they always had been done before the Taiwanese got involved!!!
PlainBill
__________________
Do not PM me if you have a repair question for me, ask it in the forum. There are many people at least as knowledgeable as I am, and that way the answer is available to everybody.
Getting good pictures.
Information on adding pictures to posts.
Which caps should you use?
Where you can buy them.
PlainBill is offline   Reply With Quote
Old 07-29-2010, 04:51 PM   #10
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Asus + PcChips = ASSrock
Asus designs, PcChips [more correctly: Hsing Tech] builds.
Asus's bright idea to gain a chunk of the low dollar market.
For PcChips:
Hsing Tech = Manufacturing branch.
PcChips = Distribution branch.
[Same corporation.]
Not sure if ECS has the same arrangement as Asus or if PcChips and ECS simply merged.
__________________
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 07-29-2010, 05:10 PM   #11
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Once in a great while someone will make up a bad silk screen to mark their boards.
When that happens just some of the cap polarity markings may be reversed.
Always best to make up a map of the PCB showing the original cap polarities before you start pulling caps.
Old 07-29-2010, 05:57 PM   #12
370forlife
Spoot
370forlife's Avatar
For PcChips:
[Same corporation.]
I think Hsing Tech is the name of the factory that ECS and PCChips have. When hardwaresecrets took a tour of the ECS factory there were PCChips on display next to ECS boards and pallets of PCChips boards around.
Old 07-29-2010, 08:30 PM   #13
c_hegge
Nut Case
c_hegge's Avatar
I always believed that ECS branded their low quality boards ECS and their VERY low quality boards PCChips.
Old 07-30-2010, 06:04 AM   #14
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Quote:
That's what I said.
The ECS association with them is new in the last few years though.
Hsing Tech and PcChips have been around since the early 90's.
I spoke [via email, in the late 90's] with the General Manager of Hsing Tech about having a custom board built. I wanted 100. I didn't have enough cash for the minimum order of 10,000 boards.
Old 07-30-2010, 08:17 PM   #15
Oerg866
wait what...?!
ASRock = backwards too? I have been trying to fix an Abit IS7- E without most caps and it doesn't POST --- are they really backwards? you have to be kidding me
all that work only to take em out and put em back in the otherway around
NOOOOOOOOOOOOOOOOOOOOOOOOOOO
Oerg866 is offline   Reply With Quote
Old 07-31-2010, 08:53 AM   #16
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
What does ASRock have to do with Abit?
Old 08-07-2010, 01:24 AM   #17
Oerg866
My fault sorry, I mixed them up %)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2010
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Advertise on this forum!
