Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Major Manufacturers Boards
Thread Tools Display Modes
Old 05-17-2010, 03:51 PM   #1
goodpsusearch
City & State: Thessaloniki, Greece
My Country: Greece
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Default Easy solution for Intel D845PESV needed
http://www.intel.com/p/en_US/support...oards/d845pesv
It seems some idiot pulled out the northbridge heatsink violently. I am looking for the easiest way to put it back... Any help welcome.
One more problem is the 3 failed KZG caps. The board does not boot at all. This is strange to me, as I have an Abit VL6 with nearly every cap on it bulging and/or leaking from bottom but it boots normally.. Do you think after a recap there are chances to work?
goodpsusearch is offline   Reply With Quote
Old 05-17-2010, 04:20 PM   #2
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 120VAC 60Hz
I'm a: Professional Tech
Default Re: Easy solution for Intel D845PESV needed
Recap it and solder the anchors back in. That will cure all, it should work. If you don't have the anchors, harvest them from a scrap board or make them from leads you've trimmed off the new caps when you replace them.
__________________
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 05-17-2010, 04:31 PM   #3
Scenic
o.O
Scenic's Avatar
City & State: Duisburg
My Country: Germany
that board is toast.
second pic, upper right corner directly below the CPU retention module.
plus the ripped-off smd parts directly next to the northbridge
another piece of hardware killed by some idiot who knows nothing about this stuff
edit: judging by the dent in the ram slot, that idiot tried to pry the heatsink off with a screwdriver. maybe he didn't even meant to remove the chipset heatsink, but the CPU retention module (without even getting the white split-pins out)
__________________
The USA have Barack Obama, Bob Hope, Stevie Wonder and Jonny Cash.
We have Angela Merkel, no hope, no wonder, no cash.
Scenic is offline   Reply With Quote
Old 05-17-2010, 04:55 PM   #4
goodpsusearch
My Country: Greece
I feel stupid I didn't notice that before... Thank you... To bad for the poor mobo...
Yeap, he did the same thing at more than 10 motherboards in order to take the p4 cpus...
Old 05-17-2010, 05:17 PM   #5
Topcat
The Boss Stooge
Topcat's Avatar
I didn't catch that either. Just looked at the anchors and the caps.....lol
Yes, that board is a goner.
Old 05-17-2010, 06:36 PM   #6
goodpsusearch
My Country: Greece
Btw I have that agp card that is tested and working but same idiot has removed its heatsink.
The gpu doesn't get too hot, I would like to add a heatsink though. How am I going to do this? There are no holes on the board to support a heasink.
Someone suggested me to put logo glue among gpu and sink. Is this safe or a completely crazy idea?
Old 05-17-2010, 09:21 PM   #7
yyonline
City & State: Pennsylvania
My Country: USA
I use Arctic Alumina:
http://www.arcticsilver.com/arctic_a...l_adhesive.htm
I've attached oodles of random heatsinks with it. Good stuff. Smells awful when you're using it though (until it dries).
That's a GeForce2 MX card. Not all of them came with heatsinks, so you could likely run it safely with no heatsink. Of course, it's a good idea to add a heatsink if you're going to use it for anything beyond the windows desktop.
yyonline is offline   Reply With Quote
Old 05-17-2010, 09:35 PM   #8
c_hegge
c_hegge's Avatar
City & State: North Coast, NSW
My Country: Australia
Line Voltage: 240V 50Hz
yyonline, that's exactly what I would be doing. I have some Arctic silver thermal adhesive. I've used it to stick heatsinks to a few FX5200 and FX5500 GPUs and a few northbridges when the fan fails or when the heatsink they come with is inadequate.
__________________
c_hegge is offline   Reply With Quote
Old 07-27-2010, 02:03 PM   #9
goodpsusearch
My Country: Greece
I found 2 more Intel D845PESV Boards.
The oldest of them has Nichicon HD and Nichicon HM (code H0319).
The HMs of that motherboard are ok, but it seems they had problems with them, so on the next version they put Nippon Chemicon KZE, Nippon Chemicon KZG and Nichicon HD again.
But KZGs don't like heat, so they bulged...
Finally on the most recent board (judging from the southbridge S/N) they put Rubycon ZL and MBZ.
Too bad that every small cap on them is 85C rated...
Old 07-27-2010, 02:21 PM   #10
yyonline
My Country: USA
I don't know that you can really go on manufacturing dates for the capacitor brand selection. I once assembled 3 computers using Intel 845 boards and the motherboards had sequential serial numbers. Despite this, each board used a different brand of caps. All 3 ended up having failed caps eventually (KZG and HM in various locations on the board) and all are still in service now after having been repaired.
Old 07-27-2010, 08:17 PM   #11
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
My Country: USA
dang... some people need to learn not to pull random heatsinks...
__________________
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 07-28-2010, 04:15 PM   #12
goodpsusearch
My Country: Greece
Quote:
Btw, I used arctic silver thermal adhesive to attach a heatsink to that card.
I also found another gforce2mx 200, that has its stock heatsink on and decided to put a cooler on it cause it got very hot after some minutes of use..
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2017
Powered by vBulletin ®
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
