Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Major Manufacturers Boards
Register FAQ Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 01-15-2010, 12:02 PM   #1
fety
Question GX270 Substitute cap values?
This GX270 I have has 9 6.3v 1800uf 8x20mm caps all along the cpu and I have on hand a bunch of 6.3v 1500uf 8x20mm Rubycon MCZ caps. Will these work? or do I HAVE TO use 1800uf?
I already plan on using them to replace the 1500uf 10x12.5mm ones around the ram slots.
Let me know please, thanks!
fety is offline   Reply With Quote
Old 01-18-2010, 03:48 PM   #2
fety
Exclamation Re: GX270 Substitute cap values?
!!!!!!!!!! EDIT !!!!!!!!!
OK hold up, I'm an idiot. I had my values all messed up.
Correction:
The ones along the cpu are 1800uf, I have on hand a bunch of 6.3v 1800uf 8x20mm Rubycon MCZ caps, can I use these to replace the five 6.3v 1500uf 10x12.5mm ones around the ram slots???? I've read I can use 10v 1500uf, but have all these 1800uf and would like to use them if I could.
Old 01-18-2010, 04:54 PM   #3
etnietering
City & State: Michigan
Default Re: GX270 Substitute cap values?
Yeah that shouldn't be a problem, as long as the fact that they're physically taller won't cause issues.
etnietering is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2013
Powered by vBulletin ®
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
